Author Topic: Which clock are you using?  (Read 4705 times)
pfriedel@gmail.com
« on: August 23, 2012, 09:33:19 pm »
I think I've seen it somewhere in the various updates, but are you using the internal RC or the PLL clock on the tiny85?  i.e. 8MHz or 16MHz?  I have a project/shield idea that's really kind of nice, but it only firms up at 16MHz.  I imagine that the fuses will be a little on the untouchable side of things since it sounds like you've set RSTDISBL to get P5 available as a pin.
« Last Edit: August 23, 2012, 09:33:19 pm by pfriedel »
sparr
« Reply #1 on: August 24, 2012, 05:33:42 pm »
You can hit fuses with high voltage programmers even with RSTDISBL enabled :)
« Reply #2 on: August 24, 2012, 05:38:02 pm »
16.5Mhz and yes it will take a HV programmer circuit to reprogram the fuses
« Reply #3 on: August 24, 2012, 05:38:18 pm »
Sparr you beat me to it - thanks!
