Author Topic: "MOD_GUI_LEFT" Just prints an E  (Read 5627 times)
yocool13
« on: January 31, 2017, 01:29:44 pm »
I tried making a simple test script that would open Rick Astleys "Never gonna give you up" but when I test it after uploading it, it doesnt press the Windows key, instead it just prints an E.
#include "DigiKeyboard.h"
  // don't need to set anything up to use DigiKeyboard
  // this is generally not necessary but with some older systems it seems to
  // prevent missing the first character after a delay:
    DigiKeyboard.delay(500);
  DigiKeyboard.sendKeyStroke(MOD_GUI_LEFT);
    DigiKeyboard.delay(750);
    DigiKeyboard.print("https://www.youtube.com/watch?v=dQw4w9WgXcQ");
    DigiKeyboard.delay(800);
    DigiKeyboard.delay(5000);
Re: "MOD_GUI_LEFT" Just prints an E
« Reply #1 on: January 31, 2017, 02:45:29 pm »
Perhaps this will do what you want:
DigiKeyboard.sendKeyStroke('r',MOD_GUI_LEFT);
yocool13
« Reply #2 on: February 02, 2017, 03:16:06 am »
That seems to have done the trick. I also have a different problem where “  DigiKeyboard.sendKeyStroke(KEY_DELETE, MOD_ALT_RIGHT | MOD_CONTROL_LEFT);“ doesnt do anything at all.
« Reply #3 on: February 02, 2017, 10:10:02 am »
I don't see KEY_DELETE defined in DigiKeyboard.h. You could try adding #define KEY_DELETE 0x63 (or 99) which I believe is (haven't tested it) the code for the numeric pad del key.
MaMe82
« Reply #4 on: February 07, 2017, 05:31:42 am »
For EN_US keyboard layout, the USB code for delete key is 0x4C (see http://www.freebsddiary.org/APC/usb_hid_usages.php)
MaMe82
« Reply #5 on: February 07, 2017, 05:44:05 am »
In order to use MOD_UI left (without combining it with the "r" key, which is used for run on windows) use
DigiKeyboard.sendKeystroke(0xe3, 0x08)
Which uses 0xe3 as key (GUI_LEFT) and 0x08 as modifier (GUI_LEFT_MODIFIER).
This is usesful on systems, where the GUI key is used without combining it with additional keys.
