Author Topic: Breakout Shield A vs B  (Read 3810 times)
bsilva
« on: August 17, 2012, 03:04:11 pm »
I see a problem with the descriptions for the A & B Breakout shields.   The A shield says the center pin is 5V and the B unit says the center pin is signal.   However, the description of the B shield says that it works with most servos.   This is incorrect, every servo I've used has had the power on the center pin.   I just did some googling and was not able to find any examples of servos currently in production that put the signal on the center pin.  Apparently older Airtronics servos were wired this way, but are not for current units.
I recommend updating the description.
Brad
« Last Edit: August 17, 2012, 03:04:11 pm by bsilva »
Dennis
« Reply #1 on: August 17, 2012, 04:50:30 pm »
This seems to be a misunderstanding. I asked for GND/Pin/5v since one of my projects used such sensors and servos. One of my friends was responsible for our servos. At some point we had to replace the servo wires and decided to change the configuration as well.
But you are right 99% are GND/5v/Pin or 5v/GND/Pin.
I\'m sorry about that misunderstanding.
« Last Edit: August 17, 2012, 04:51:39 pm by Dennis »
sparr
« Reply #2 on: August 17, 2012, 06:49:14 pm »
I, too, have used gnd/pin/5v servos.
