Digistump Forums
Back to Digistump.com
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Login
Register
Digistump Forums
The Digispark
Digispark (Original) Support
Digispark Relay Kit Shield
« previous
next »
Print
Pages: [
1
Author
Topic: Digispark Relay Kit Shield (Read 1915 times)
bradlee_s
Newbie
on:
November 09, 2017, 06:56:23 pm »
Can this be used to control a 16VAC door buzzer? I see it says 125VAC/250VAC. Are those maximums? Would 16VAC work with the relay?
Logged
KASA
Newbie
Re: Digispark Relay Kit Shield
Reply #1 on:
December 23, 2017, 01:23:44 pm »
This would absolutely work. Here
https://digistump.com/wiki/digispark/tutorials/relay
it says up to 5 Amps for 30VAC but you can look up further details in the data sheet of the relays (Omron G5Q)
Logged
Hero Member
Reply #2 on:
December 27, 2017, 07:31:00 pm »
As KASA said, it would absolutely work
And yes, those are the maximums, which also mean and you should be able to switch higher currents/amperages as you drop the voltage (i.e. can switch a 5A load at 250VAC, or a 10A load at 125VAC).
Logged
Print
Pages: [
1
« previous
next »
Digistump Forums
The Digispark
