I'm trying to get some sound from the Digix by playing an wav from the SD-card.
I have connected some headphone to the stereo jacked, but i'm not able to hear anything.
Is my sketch not correct for the DigiX?
Demonstrates the use of the Audio library for the Arduino Due
Hardware required :
*Arduino shield with a SD card on CS 4 (the Ethernet sheild will work)
*Speaker attched to ground and DAC0
Original by Massimo Banzi September 20, 2012
Modified by Scott Fitzgerald October 19, 2012
#include <SD.h>
#include <SPI.h>
#include <Audio.h>
// debug output at 9600 baud
Serial.begin(9600);
while(!Serial.available()){
delay(1000);
// setup SD-card
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println(" failed!");
return;
Serial.println(" done.");
// hi-speed SPI transfers
SPI.setClockDivider(4);
// 44100 Hz stereo => 88200 sample rate
// 100 mSec of prebuffering.
Audio.begin(88200, 100);
int count=0;
// open wave file from sdcard
File myFile = SD.open("test.wav");
if (!myFile) {
// if the file didn't open, print an error and stop
Serial.println("error opening test.wav");
while (true);
const int S=1024; // Number of samples to read in block
short buffer;
Serial.print("Playing");
// until the file is not finished
while (myFile.available()) {
// read from the file into buffer
myFile.read(buffer, sizeof(buffer));
// Prepare samples
int volume = 1023;
Audio.prepare(buffer, S, volume);
// Feed samples to audio
Audio.write(buffer, S);
// Every 100 block print a '.'
count++;
if (count == 100) {
Serial.print(".");
count = 0;
myFile.close();
Serial.println("End of file. Thank you for listening!");
while (true) ;
