Author Topic: Min Max temperature on I2C 16x2 LCD  (Read 15131 times)
Mark
Re: Min Max temperature on I2C 16x2 LCD
« Reply #15 on: May 31, 2013, 11:13:55 am »
gcmm3
If you're talking about the Digispark there is no FTDI driver, as there is no FTDI USB to serial conversion chip on board.
You use the windows driver install, and it loads it.
I suggest removing any that windows marks as failed, before running it.
There have been a few others that have had issues with the newer USB ports needing the Digispark to be tweaked sideways slightly.
The fact that you got it working on the 15th tends to point to a connection problem, which the powered hub should have overcome.....
If you want code to run on a full Arduino, I can link to some, since I'm not sure this does with the modified library.
Mark
