Author Topic: wireless programming  (Read 2717 times)
robb
« on: August 29, 2012, 09:15:17 pm »
The digispark is programmed via usb which only uses two data pins. It should be possible to also program the digispark via a serial wireless module. I'm not familiar with how exactly the digissaprk firmware works beyond the fact its based on vusb. I assume the firmware would need to be modified to accommodate this. It should be possible though.
« Last Edit: August 29, 2012, 09:15:17 pm by robb »
robb
« Reply #1 on: August 31, 2012, 07:00:04 am »
« Reply #2 on: November 04, 2012, 04:21:14 am »
Re \"only uses two data pins\" TinySafeBoot, an alternative which requires a serial adaptor but frees up 1.5kb of extra program memory, can work with just one pin! Kinda neat. I still think USB is better though.
