Author Topic: request: simple, vague description of shield  (Read 7925 times)
MrGadget
« on: August 24, 2012, 07:04:41 pm »
Can you (whoever responsible) post a simple, vague description of each shield on the shield main page? To be Noob, "Mac user" friendly (you get the joke?) (No offense)
Ex:
        MOSFET: output Maximizer up to 35V
        Boost Shield: input minimizer 2-4.5
Etc.
« Last Edit: August 24, 2012, 07:04:41 pm by MrGadget »
sparr
« Reply #1 on: August 25, 2012, 03:43:48 am »
Your examples don\'t make sense to me.
MrGadget
« Reply #2 on: August 25, 2012, 05:17:18 pm »
But you get the point do you?
gemay
« Reply #3 on: August 26, 2012, 09:48:53 pm »
I agree with MrGadget - What is a Grove Shield?? What does it do?  What\'s the difference between a Motor shield and a Mosfet Shield?  What does a boost shield do?
Thanks!!
MichaelMeissner
« Reply #4 on: August 27, 2012, 05:46:45 am »
Grove shields are meant to use the Grove system of sensors, that all use a common 4 wire plug.  I believe Grove was created by seeedstudio, and you can read more about it here: http://www.seeedstudio.com/wiki/GROVE_System.  The advantage of the grove system is it is plug and play and needs no soldering in the original Grove system.  However with the digispark, I believe you will need to do a little soldering to make the Grove shield itself.
A boost shield is meant to take a battery which is less than 5 volts and use voltage converters to increase the voltage to 5 volts so that the digispark can run.  Example batteries include 2 AA batteries that provide up to 3 volts (alkaline) or 2.4 volts (Nimh rechargeable) or many common LiPo batteries which run at 3.7 volts.
I believe the MOSFET shield is a little like a boost shield in reverse, and it would allow you to control higher voltage devices from the digispark.  You might be able to use MOSFETs to drive motors, but if you want to control a motor, you should get a motor shield, unless you want to do all of the programming to control the motor.
I should mention besides normal motors, there is a variant called servos that are controlled differently.  A motor spins in one direction or another, and you have to tell it when to stop, and what direction/speed to use.  A servo is setup to move between 0 and some limit (usually 180) degrees, and you just tell which position to move to.  For many robotic controls, a servo is better than a more general motor.  You would not use the motor shield to control the servo, but instead no shield, the through the hole shield, or one of the breakout shields (I forget which breakout shield is wired for servos).
« Last Edit: August 27, 2012, 06:01:08 am by MichaelMeissner »
gemay
« Reply #5 on: August 27, 2012, 07:03:25 am »
MichaelMeissner - Great information! Thank you!
MrGadget
« Reply #6 on: August 29, 2012, 02:55:35 am »
Thanks Michael.
That\'s what should be on the backer page and/or the main page.
if you can please tell us what the other shields do? and/or the point of using them
BWood
« Reply #7 on: August 29, 2012, 03:22:33 am »
I agree, this information should be on the backer and/or main page.
I\'m also wondering what the purpose of the expander shield is?  Would it allow me to run more things?  Could I wire a Motor Controller and an RGB to it and control both of them?
Thanks
MichaelMeissner
« Reply #8 on: August 29, 2012, 04:37:46 am »
Update #10 talks about the new shields: http://www.kickstarter.com/projects/digistump/digispark-the-tiny-arduino-enabled-usb-dev-board/posts
In particular, the expander shield allows you to have more input/output lines using the i2c bus (you get 8 i/o pins at a cost of using the 2 i2c pins).  These can be stacked (with the purchase of stacker pins as well as 2 or more shields).
Now, to read/write an i2c pin uses different functions than the normal functions, so you would have to change your code to use it.  I don\'t recall if you can do PWM (pulse width modulation) which is the way Arduinos do it, so you might not be able to use i2c for motor control.
Here is a tutorial on i2c I found via google: http://tronixstuff.wordpress.com/2010/10/20/tutorial-arduino-and-the-i2c-bus/
