Author Topic: Get Product Serial Key  (Read 10383 times)
Lines_of_codes
« on: July 29, 2019, 02:26:01 am »
By original if you want to get a serial key box (ex. Windows) then if you need it open a paper with serial key. but I have an idea to make
Products Serial Key - Arduino Serial Key (P.S.K.-A.S.K.)
then if you plug-in Digispark then open the program* that made by me name
Products Serial Key - Arduino Serial Key Reader (P.S.K.-A.S.K.R.)
*My Program use Microsoft .NET Framework 4.8 hope you know who install VS201x with Framework 4.8 don't have to install.
And this use SerialPort Funtion
This is an example of code (4kb)**
  Serial.begin(9600);
  //Baud Rate
    if(Serial.available()>0)
  //check serial port then wait until it connect to pc
   String txt=Serial.readString();
   if(txt=="abt-dev")
  //txt = textbox1 in application
    Serial.println("S Universal Group")
  //println will return a message to richtextbox1 in application
    else if(txt=="get-serialkey")
      Serial.println("G.P.I.S.K: 29/7/2019-001-1.0.2.1-infs-9600")
    else if(txt=="abt-softwaren")
      Serial.println("MoneyCalculate")
    else if(txt="abt")
      Serial.println("Products Serial Key - Arduino Serial Key (P.S.K.-A.S.K.) Use with P.S.K.-A.S.K.R (Reader)")
      Serial.println("Develop by S Universal Studio")
      Serial.println("Abt command = abt-softwaren (Software to get a serial key), abt-dev (tell developer group-name)")
      Serial.println("type 'get-serialkey' to get a serial key! ")
**Serial Code are NOT availeble to use at this time. it can use only when i made this
