Author Topic: Trouble Getting Oak To Work  (Read 733 times)
ktf
« on: November 25, 2018, 04:02:19 pm »
Hello,
I bought my Oak in the original kick starter campaign. I bought 3, but so far I'm very disappointed. I had a lot of issues trying to get the device to connect to wifi. Lots of forum searches and it looks like this is a common problem that is still not fixed (why not?).
For anyone looking, what worked for me was to download FireFox 44 (https://ftp.mozilla.org/pub/firefox/releases/44.0b9/), and then open a locally saved copy of the setup page (https://rawgit.com/digistump/OakSoftAP/master/config.html). Initially the firmware failed but finally made it on the second try. Then I manually retrieved the device ID (http://192.168.0.1/device-id while connected to its wifi) to add it to the Particle Cloud and that seemed to work. I could ping it from the Particle IDE and that worked fine- it showed it was connected.
I was pretty happy, until I tried flashing a program to it. Nothing. It would restart and the status in the Particle console showing events was "No user rom found", which I came to find out meant it did not flash the program. Not that it wasn't obvious because I flashed a simple LED blink program & tried registering a variable in the Particle cloud and that did not work. I spend a lot of time but nothing. It was stuck with the 3-quick flash blink. :-\
Meanwhile trying to flash my second Oak, the second Oak's wifi SSID name seems to have some odd unicode symbol at the end, and won't show on my list of devices to connect to on my computer. It did show on my iPhone, and it does show on my list of networks if I run "netsh wlan show networks" from the command line- but I can't connect to it from the command line either. I have no clue why this is the case on the second but not the first Oak.
I feel very frustrated and disappointing that I spent the last 4 hours  getting nowhere. The most frustrating part of all this is it seems like this is not uncommon, but there are no/few efforts to resolve this, and activity in the forums seems weak.
I'm starting to realize maybe I bought the hardware version of vaporware.
I guess this is mostly a rant, although I'd love any direction on how to move forward next. Currently, it seems the only Oak I was able to get connected to the cloud is no longer even doing that (I tried changing the firmware from the Particle IDE and that seems like it was a bad idea). I'm thinking maybe I can purchase this guy and see if I can follow some of the instructions to update the firmware:
https://www.amazon.com/WINGONEER-converter-CH340G-Serial-Adapter/dp/B01DC0D9U2/ref=sr_1_8?ie=UTF8&qid=1543190407&sr=8-8&keywords=USB+to+TTL+CH340G
However from what I've read it looks like there's issues with the Particle cloud. If this is the case, will I not be able to flash programs to the device over wifi? If not, this dramatically lowers the advantage of the Oak to me. Right now I'm feeling like I threw away money and the authors have gone MIA to their next project.  :-[
JeffRand
Re: Trouble Getting Oak To Work
« Reply #1 on: November 26, 2018, 01:15:42 pm »
I'm sorry, I don't think I can help you with your Oaks. I never got mine working either. There are some folks on here that should be able to help you get them working if you're willing to invest the time and expense.
I gave up on trying to get the Oaks to do what was advertised. Like you said, Erik practically abandoned Digistump and moved on to his BuildOne project, which is very far behind schedule. I knew that was going to be the case when he first announced it. Those folks that backed the BuildOne should have realized that he was taking on too much.
I ended up going with Photons from Particle. I have been very happy with them and haven't had any problems. The Photons work as advertised.
ktf
« Reply #2 on: December 02, 2018, 04:55:54 pm »
Thanks for responding, JeffRand. I do have a couple particle/photons and they work great. I think I need to just stick with those as well.
