As it is said, I can't find the way to leave pressed a key of the type MOD. I have already defined on "DigiKeyboard.h" the key to be pressed (in this case, left shift), but it does not behaves as any other key. I added on the library file:
#define KEY_SHIFT_LEFT 225
And the code is:
DigiKeyboard.sendKeyPress(225);
DigiKeyboard.delay(200);
DigiKeyboard.sendKeyPress(4);
DigiKeyboard.sendKeyPress(0,0);
The instructions are: "Press left shift, wait 0.2 sec, press letter "a", release all, repeat."
So the output should be "A" every 0.2 sec. Instead, I get "a".
Do you know any other way to press left shift? Thank you community.
