Author Topic: SoftSerial example not compiling  (Read 4795 times)
jusep
« on: June 24, 2018, 11:40:37 am »
Hi all!
I have a Digispark with a thermometer shield I designed. Now, I would like to make some reading to the sensor and send them to the computer. I would like to have a bidirectional communication between the PC and the Digispark. To do so, I thought that the SoftSerialExample would be a good starting point. However, I encountered some issues. First, there was a compiling error in line:
while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
Telling me that:
tmp/arduino_modified_sketch_408992/SoftSerialExample.ino: In function 'void setup()':
SoftSerialExample:32: error: no match for 'operator!' (operand type is 'TinyDebugSerial')
    while (!Serial) {
/tmp/arduino_modified_sketch_408992/SoftSerialExample.ino:32:11: note: candidate is:
/tmp/arduino_modified_sketch_408992/SoftSerialExample.ino:32:11: note: operator!(bool) <built-in>
/tmp/arduino_modified_sketch_408992/SoftSerialExample.ino:32:11: note:   no known conversion for argument 1 from 'TinyDebugSerial' to 'bool'
exit status 1
However, given that this line is needed for Leornardo only I commented it. Next, however, more compiling errors appear:
SoftSerialExample:37: error: 'Serial' does not name a type
   Serial.println("Goodnight moon!");
SoftSerialExample:40: error: 'mySerial' does not name a type
   mySerial.begin(4800);
SoftSerialExample:41: error: 'mySerial' does not name a type
   mySerial.println("Hello, world?");
SoftSerialExample:42: error: expected declaration before '}' token
exit status 1
I am clueless on how to fix it. Could you please give me some guidance? I am using Arduino IDE 1.8.5 on an Ubuntu 14.04 LTS.
Thanks in advance!
Jusep
robvd
Re: SoftSerial example not compiling
« Reply #1 on: July 08, 2018, 01:41:40 pm »
Hello Jusep,
Did you create the serial object?
Something like
  #include <SoftSerial.h>                 // SoftSerial en TinyPinChange voor DigiSpark
  #include <TinyPinChange.h>
  SoftSerial MySerial(RX, TX);     // RX, TX pins
Also the "}" error may be the problem. Sometimes the errors are not clear when something else is wrong and one } to many or too few may give all kind of errors….
Rob
Rob
jusep
« Reply #2 on: July 12, 2018, 12:34:11 am »
Hi Rob,
I am using the example code provided when you install Digispark board on Arduino IDE. Of course, the serial object is created.
Talking with a friend some days ago he proposed to use DigiCDC library for this purpose, so I'll give it a try.
  Software serial multiple serial test
 Receives from the hardware serial, sends to software serial.
 Receives from software serial, sends to hardware serial.
 The circuit:
 * RX is digital pin 2 (connect to TX of other device)
 * TX is digital pin 3 (connect to RX of other device)
 created back in the mists of time
 modified 9 Apr 2012
 by Tom Igoe
 based on Mikal Hart's example
 This example code is in the public domain.
 <SoftSerial> adapted from <SoftwareSerial> for <TinyPinChange> library which allows sharing the Pin Change Interrupt Vector.
 Single difference with <SoftwareSerial>: add #include <TinyPinChange.h>  at the top of your sketch.
 RC Navy (2012): http://p.loussouarn.free.fr
#include <SoftSerial.h>     /* Allows Pin Change Interrupt Vector Sharing */
#include <TinyPinChange.h>  /* Ne pas oublier d'inclure la librairie <TinyPinChange> qui est utilisee par la librairie <RcSeq> */
SoftSerial mySerial(2, 3); // RX, TX
 // Open serial communications and wait for port to open:
  Serial.begin(57600);
   while (!Serial) {
  // set the data rate for the SoftwareSerial port
void loop() // run over and over
  if (mySerial.available())
    Serial.write(mySerial.read());
  if (Serial.available())
    mySerial.write(Serial.read());
