Author Topic: Custom Gaming keypad  (Read 3807 times)
BaDjinn
« on: March 20, 2018, 03:57:19 pm »
Hi to everyone!
I'm new of this forum so if i posted in the wrong section please let me know!
Now, my objective is to build a gaming keypad to use it for gaming (of course) and productivity by managing it through any of the various macro programs aviable. But since it's my first attempt i started small: a 5 button keypad, directly wired to the digispark, and using the DigiJoystick library.
The example script gives no problems and windows 10 pro sees the digispark as a joypad.
The problem came when i added the buttons. The code compile but the device it's not acknowledged as a joypad anymore and gives "unknown USB device".  :o
Here my code:
#include "DigiJoystick.h"
byte bStateL = 0x00;
byte bStateH = 0x00;
 for (int i =0; i < 5; ++i ){
  pinMode(i, INPUT_PULLUP);
  //DigiJoystick.delay(100);
  for (int j=0; j<5; j++){
  byte bVar = readButton(j);
   bStateL |= (bVar<<j);
  DigiJoystick.setButtons(bStateL, bStateH);
  DigiJoystick.delay(10);
byte readButton(int pin){
  if(digitalRead(pin) == HIGH){
      return 0x01;
  return 0x00;
Is it a problem of timing(delay)? I can't find answers anywhere, so i'm asking to you gurus :'(
BaDjinn
Re: Custom Gaming keypad
« Reply #1 on: March 22, 2018, 08:51:36 am »
Ok, ok, ok...
After some more troubleshooting i found that not all of the digital pins of the digispark works well with the "INPUT_PULLUP" pinMode. Seems like i'll need some cd4021 after all...
