Author Topic: Powering Digispark Pro directly with 3S 11.1V LIPO battery  (Read 1631 times)
rimakus
Hello all,
I was wondering if anyone tried to power up Digispark Pro using 11.1v (12.6v when fully charged) LIPO battery via VIN pin. I know it says 6-16v on the diagram but usually other manufacturers recommend 7-12v ranges e.g. I am afraid that it could be too much for it.
Thanks in advance.
MrCookie
Re: Powering Digispark Pro directly with 3S 11.1V LIPO battery
« Reply #1 on: April 11, 2018, 11:34:54 am »
I have powered a pair of powered goggles with 48.75 amp lipo battery. Which is overkill since the goggles only use 380 mAh @ 12 volts, when in use. Big batteries do not damage low amp electronics, instead, your left with a battery that holds a charge for a very very long time. Now.. big batteries can explode or do nasty things if there is a short, since you probably don't have a fuse on your 3S 11.1V lipo.
Even a fast acting 1 amp fuse, or something like the resettable LittelFuse 1.25 Amp fuse might be something to look at:
https://www.digikey.com/product-detail/en/littelfuse-inc/07771.25MRET1P/F6711CT-ND/5180595
« Last Edit: April 25, 2018, 03:32:06 am by MrCookie »
