Author Topic: Led flasher for ulm aircraft  (Read 5514 times)
Airmonterosa
« on: March 12, 2017, 09:21:00 am »
Goodmorning everyone! I'm trying to create a sketch for one strobe flasher to install on my ultralight.
What my Digispark should do is this: three fast flashes every 2 I'm using a digispark connected whith a mosfet transistor.
 Thank so much for any kind of help.
Michele
Re: Led flasher for ulm aircraft
« Reply #1 on: March 12, 2017, 10:15:09 am »
Here is a sketch that flashes the onboard LED (currently set for Arduino). You can tie into the appropriate pin (1 for Digispark) and adjust the strobe parameters as needed.
Don't fall out of the sky. No warranties implied or otherwise given. Use at your own risk.
  Strobe
  Turns on an LED and off in a burst of strobes then delays for a specified
  period before repeating the strobe pattern.
  To configure set the following parameters:
  strobeNumber - number of flashes in strobe sequence
  strobeOn - duration of flash in milliseconds
  strobeOff - delay between flashes in milliseconds
  strobeDelay - delay between strobe sequence in milliseconds
// Adjust the following strobe parameters as needed
int strobeNumber = 3;
int strobeOn = 100;
int strobeOff = 200;
int strobeDelay = 2000;
int LEDpin = 13; // 13 Arduino, 1 Digispark
  // initialize digital pin LED_BUILTIN as an output.
  pinMode(LEDpin, OUTPUT);
  for(int i=0; i<strobeNumber; i++) {
     digitalWrite(LEDpin, HIGH);   // turn the LED on
     delay(strobeOn);
     digitalWrite(LEDpin, LOW);    // turn the LED off
     delay(strobeOff);
  delay(strobeDelay-strobeOff); // Because we already delayed for strobeOff (ms)
Airmonterosa
« Reply #2 on: March 12, 2017, 11:26:36 am »
Thank so much for the very fast reponse! I'll try to adapt your sketch to my Digispark.
Airmonterosa
« Reply #3 on: March 17, 2017, 05:01:35 am »
and if I wanted to add a second blinking light with a different frequency? Can i do this with a single mosfet, or I have to add another?
I have to set a second output (P1 or what?)
Many many thanks
« Reply #4 on: March 17, 2017, 09:13:49 am »
A second control circuit would be necessary, on a second pin but then your code gets a little more complicated. You would have to multiplex the control somehow so that you are flashing each at a different rate. It would take some thought to come up with a solution. There may be some interrupt based methods of doing this but haven't seen or used them.
The dead simple way is to use another Digispark.
« Reply #5 on: March 17, 2017, 11:57:13 pm »
I don't know if this helps, but this was the code I wrote about four years ago for a led strobe controller for a quadcopter, which was based on an ATTiny85, so should be easy to transfer to a Digispark. It was plugged into an auxiliary channel of the quads receiver, so the pattern to be used was controlled by the transmitter.
I know it is a let more complicated than the sketch that exeng gave earlier, but it does a lot more, and shows one way to control multiple pins with multiple pattern sets. Unfortunately, I can't say for certain whether I finished this version of the code, and I see there is some code in it from the previous revision that is now redundant / not needed.
   PIN 0 / STARBOARD / RIGHT / GREEN
   PIN 1 / STROBE    / REAR  / WHITE
   PIN 2 / PORT      / LEFT  / RED
   PIN 4 / RC_SIGNAL /  RC RECEIVER
#define STARBOARD 0
#define STROBE 1
#define PORT 2
#define RC_SIGNAL 4
#define NUM_PATTERNS 5
long currentMillis;
int rcSignal = 0;
byte currMode = 0;
byte lastMode = 25;
PROGMEM  prog_uchar   masterPatternStates[NUM_PATTERNS][3][10] = { {{0,255},              {0,255},              {0,255}},
                                                        {{1,0,255},            {0,1,0,255},          {0,1,0,255}},
                                                        {{0,255},              {1,0,1,0,255},        {0,255}},
                                                        {{1,0,1,255},          {1,0,1,255},          {0,1,0,1,255}},
                                                        {{0,1,255},            {0,1,255},            {1,0,255}}
PROGMEM  prog_uint16_t masterPatternTimes[NUM_PATTERNS][3][10] = { {{0},              {0},              {0}},
                                                        {{50,1200},        {100,50,1100},    {200,50,1000}},
                                                        {{0},              {50,100,50,100},  {0}},
                                                        {{1000,50,500},    {500,50,1000},    {1200,75,150,75}},
                                                        {{1900,100},       {1900,100},       {1800,200}}
unsigned char pattern_states[3][10];
/* = {{0,1,0,1,0,1,0,1,0,255},
                                       {0,1,0,1,0,1,0,1,0,255}}; //(1 byte) 0 to 255
uint16_t pattern_times[3][10]; //(2 bytes) 0 to 65,535
int portPattern[5][10] = {
  {0,0,-1},
  {1,50,0,1200,-1},
  {0,0,-1},
  {1,1000,0,50,1,500,-1},
  {0,1900,1,100,-1}
int starboardPattern[5][10] = {
  {0,0,-1},
  {0,100,1,50,0,1100,-1},
  {1,50,0,100,1,50,0,100,-1},
  {1,500,0,50,1,1000,-1},
  {0,1900,1,100,-1}
int strobePattern[5][10] = {
  {0,0,-1},
  {0,200,1,50,0,1000,-1},
  {0,0,-1},
  {0,1200,1,75,0,150,1,75,-1},
  {1,1800,0,200,-1}
unsigned long strobe[4] = {1,0,0,0};
unsigned long port[4] = {1,0,0,0};
unsigned long starboard[4] = {1,0,0,0};
  pinMode(PORT,OUTPUT);
  pinMode(STARBOARD,OUTPUT);
  pinMode(STROBE,OUTPUT);
  pinMode(RC_SIGNAL,INPUT);
  digitalWrite(PORT,LOW);
  digitalWrite(STARBOARD,LOW);
  digitalWrite(STROBE,LOW);
  rcSignal = pulseIn(RC_SIGNAL, HIGH, 25000);
  if (rcSignal < 900) // spektrum smartsafe or no valid signal
    currMode = 1; //chaser - no signal
  else if (rcSignal >= 900 && rcSignal <= 1300) //low
    currMode = 0; //off
  else if (rcSignal > 1300 && rcSignal <= 1700) // middle
    currMode = 3; //pattern 1
  else if (rcSignal > 1700 && rcSignal <= 2100) //high
    currMode = 4; //pattern 2
  else //I don't understand?
    currMode = 2;
  if (currMode != lastMode)
    //load new pattern table
    for (int i = 0; i < NUM_PATTERNS; i++)
      for (int j = 0; j < 3; j++)
        pattern_states[i][j] = pgm_read_word(&masterPatternStates[currMode][i][j]);
    //reset counters
    // [0] mode, [1] firstRun, [2] step, [3] waitTime
    port[0]      = currMode;  port[1]      = 0;  port[2]      = 0;
    starboard[0] = currMode;  starboard[1] = 0;  starboard[2] = 0;
    strobe[0]    = currMode;  strobe[1]    = 0;  strobe[2]    = 0;
    lastMode = currMode;
  currentMillis = millis();
  //port light
  if (port[1] == 0 || currentMillis >= port[3])
    if (port[1] == 0)
      port[1] = 1;
    if (portPattern[port[0]][port[2]] == 0)
    else //if (portPattern[port[0]][port[2]] == 1)
      digitalWrite(PORT,HIGH);
    port[3] = millis() + portPattern[port[0]][port[2]+1];
    port[2] += 2;
    if (portPattern[port[0]][port[2]] == -1)
      port[2] = 0;
  //starboard light
  if (starboard[1] == 0 || currentMillis >= starboard[3]) //[3] is delay
    if (starboard[1] == 0)
      starboard[1] = 1;
    if (starboardPattern[starboard[0]][starboard[2]] == 0) //[2] is on/off flag
      digitalWrite(STARBOARD,LOW); // light off
    else //(starboardPattern[starboard[0]][starboard[2]] == 1) //[2] is on/off flag
      digitalWrite(STARBOARD,HIGH); // light on
    starboard[3] = currentMillis + starboardPattern[starboard[0]][starboard[2]+1]; //read 'delay' parameter
    starboard[2] += 2; //increment to next 'step'
    if (starboardPattern[starboard[0]][starboard[2]] == -1) // if next 'step' is '-1' - end of set
      starboard[2] = 0; // return to first instruction in set
  if (strobe[1] == 0 || currentMillis >= strobe[3])
    if (strobe[1]  == 0)
      strobe[1] = 1;
    if (strobePattern[strobe[0]][strobe[2]] == 0)
    else if (strobePattern[strobe[0]][strobe[2]] == 1)
      digitalWrite(STROBE,HIGH);
    strobe[3] = currentMillis + strobePattern[strobe[0]][strobe[2]+1];
    strobe[2] += 2;
    if (strobePattern[strobe[0]][strobe[2]] == -1)
      strobe[2] = 0;
« Reply #6 on: March 18, 2017, 04:22:41 pm »
Well Pete... saw your post this morning after dreaming about a possible solution (that's where many of my coding problems get solved). So you beat me to it.
In any case, decided to hack another example together for Michele.  Seems to work as intended.
 * ULM Multi LED Strobe
 * This example outputs 3 different LED patterns on 3 different output pins.
 * The patterns are set by simply setting a sequence of delay values to repeat.
 * These values determine the on/off delay times. For example, {100,200,100,200,100,2000} is
 * an LED pattern that is ON 100ms, OFF 200ms, ON 100ms, OFF 200ms, ON 100ms, OFF 2 seconds.
int LED1pin = 6;
int LED2pin = 7;
int LED3pin = 8;
uint16_t LED1pat[] = {100,200,100,200,100,2000}; // On/Off/On/Off... delays
uint16_t LED2pat[] = {1000,2000}; // On/Off/On/Off... delays
// Morse SOS pattern
uint16_t LED3SOS[] = {120,120,120,120,120,240,360,120,360,120,360,240,120,120,120,120,120,1000}; // dot,dot,dot pause dash,dash,dash pause dot,dot,dot long pause
uint16_t LED1size = sizeof(LED1pat)/2; // Need to know how many entries there are so we divide by 2 to get the correct number of entries not characters.
uint16_t LED2size = sizeof(LED2pat)/2;
uint16_t LED3size = sizeof(LED3SOS)/2;
uint16_t LED1idx; // For a brute force control of the pattern index.
uint16_t LED2idx;
uint16_t LED3idx;
bool LED1state; // Basically HIGH or LOW, State is toggled to control LED output.
bool LED2state;
bool LED3state;
uint32_t nextLED1chg; // Time value in millis for next scheduled LED state change.
uint32_t nextLED2chg;
uint32_t nextLED3chg;
  /* For debug
  Serial.begin(9600);
  Serial.println("ULM Multi Strobe starting");
  Serial.println(LED1size);
  Serial.println(LED2size);
  Serial.println(LED3size);
  pinMode(LED1pin, OUTPUT);
  pinMode(LED2pin, OUTPUT);
  pinMode(LED3pin, OUTPUT);
  LED1idx = 0;
  LED2idx = 0;
  LED3idx = 0;
  LED1state = 1; // init HIGH
  LED2state = 1; // init HIGH
  LED3state = 1; // init HIGH
  // All LEDs start on
  digitalWrite(LED1pin, LED1state);
  nextLED1chg = millis() + LED1pat[LED1idx]; // time for next LED state change
  digitalWrite(LED2pin, LED2state);
  nextLED2chg = millis() + LED2pat[LED2idx]; // time for next LED state change
  digitalWrite(LED3pin, LED3state);
  nextLED3chg = millis() + LED3SOS[LED3idx]; // time for next LED state change
  // First pattern
  if (millis() >= nextLED1chg) {
    // Toggle state
    LED1state = !LED1state;
    // Manage indexing through ON/OFF pattern
    ++LED1idx;
    LED1idx %= LED1size;
  // Second Pattern
  if (millis() >= nextLED2chg) {
    // Toggle state
    LED2state = !LED2state;
    ++LED2idx;
    LED2idx %= LED2size;
  // SOS (3rd) pattern
  if (millis() >= nextLED3chg) {
    // Toggle state
    LED3state = !LED3state;
    ++LED3idx;
    LED3idx %= LED3size;
@Michele, the patterns are simply on/off delay times. I tried to include enough comments so it should be easy to follow. It also contains your original 3 blink pattern and two others to demonstrate 3 LEDs flashing different patterns. Tested on an UNO. Pins were picked arbitrarily. Hope this helps.
« Last Edit: March 18, 2017, 05:22:21 pm by exeng »
« Reply #7 on: March 18, 2017, 05:35:24 pm »
More than one way to skin a cat... so more the merrier ;) Hopefully the two of these will give Michele some ideas... and if yours does the job out of the box, even better! ;) That looks pretty much the way my version 2 of the code had looked... with the code I posted being the later v3. I'd started with a fixed strobing program, and then upgraded it to a selectable pattern, and then was upgrading it further to have room for more patterns and more complex patterns, which only need you to change to two arrays for sequencing.
Airmonterosa
« Reply #8 on: March 19, 2017, 12:08:41 pm »
I dont know how to thank you guys! In the next week my cave ll'be the test lab!!!!
The last question : 3 different strobe pattern,3 mosfet,3 output but 1 Digispark?
« Reply #9 on: March 19, 2017, 12:32:36 pm »
Yep, you should be able to control the 3 with 1 Digispark.  You'll have to use different pins than the ones I selected for my example as they were selected for an Arduino UNO. You could use pins 0,1,2 as digital outputs, each connected to a different MOSFET driving the individual LEDs.
Airmonterosa
« Reply #10 on: March 19, 2017, 12:40:05 pm »
This is my flying big foot
« Reply #11 on: March 19, 2017, 03:03:47 pm »
You are braver than I. Let us know how the LED flashing works out for you.
Airmonterosa
« Reply #12 on: March 20, 2017, 08:14:12 am »
yet take advantage of your great willingness for a second project to connect the digispark to a fuel pump that  must be ON when the pressure detected by a pressure-meter  falls below a certain threshold (0.2 atm, that is  1.3 volts) and must be off when the pressure reaches 0.4 atm, that is 1.7 volts.
If any of you were to visit Italy will be my guest !!!!
