Author Topic: Help with Windows 10 driver install ?  (Read 37632 times)
JonRussell
« on: June 27, 2016, 11:37:39 am »
I cant seem to install the drivers with Windows 10.
I am running Windows 10, 1511, Build 10586.420
I downloaded the DigiSpark drivers from https://github.com/digistump/DigistumpArduino/releases/download/1.6.7/Digistump.Drivers.zip
Ran "Install Drivers.exe"
But on the final screen I get "Digistump LLC (usbser) Ports (08/16/2014 1.1.0.0) - Install Failed"
The other three drivers in the list say "Ready to use"
Any ideas ?
Thanks.
Jon.
perigalacticon
Re: Help with Windows 10 driver install ?
« Reply #1 on: July 02, 2016, 02:05:07 pm »
I have the exact same problem, did you get it fixed?  I was able to get a screenshot of the Devices and Printers Window icon that shows up for less than a second when I plug it in,  see the attachment.
There is no port created in Device Manager like for other Arduinos.
I am running Win10 64 bit professional.
Another test I made was to apply 7V btwn the Vin pin and GND pin, then insert the usb connector.  In this case windows did not respond at all, nothing happened at all when I plugged it in.  I also tried a 2nd cable and other usb ports.  I'm about to throw it in the trash.
Thanks
« Last Edit: July 02, 2016, 02:40:18 pm by perigalacticon »
JonRussell
« Reply #2 on: July 06, 2016, 02:35:41 pm »
I still have the issue. I cant seem to get any support here, or from DigiStump ... not great, seeing as they are still happy to sell the products and take your money.
I can program them on my Win10 Laptop, but not my Win10 desktop. Cant remember doing anything differently.
But I cant get the CDC examples to run on either.
I get a driver issues again.
When the DigiSpark is in CDC mode, I get "Unknown USB Device (Invalid Configuration Descriptor)" even on a machine with working drivers for programming.
Shame.
Jon.
« Last Edit: July 06, 2016, 03:05:10 pm by JonRussell »
anotherhowie
« Reply #3 on: July 07, 2016, 09:21:39 am »
I'm having similar issues - on my personal Windows 10 64-bit desktop, the drivers don't install with an red cross against installing usbser. Downloading the separate driver package instead of doing it via the Arduino IDE makes no difference.
On my work laptop (Windows 7 64bit), the drivers install but the digispark is not recognised when it's connected.
Stephenichols
« Reply #4 on: July 16, 2016, 03:23:34 pm »
Exact issue I am having. It does load "Digispark Bootloader" momentarily but then drops it due to "Digistump LLC (usbser) Ports (8/16/2014 1.1.0.0) Install failed" Status.
treii28
« Reply #5 on: August 14, 2016, 01:15:45 pm »
Same problem here. I see at least 4 different threads - NONE with any answers.
WTF digistump?? Get on the ball!
Emielkosse
« Reply #6 on: August 14, 2016, 11:29:13 pm »
Did you got the genuine Digispark? I had this issue with rev3 (clone one) changed the diodes on these and then they worked.
drWatson
« Reply #7 on: August 29, 2016, 06:35:43 am »
Try going into windows boot options and changing "Install unsigned drivers" option there. Google for detailed instructions.
bratoff
« Reply #8 on: September 05, 2016, 06:28:22 pm »
Enabling unsigned drivers in Windows 10 will get you only a little bit farther.  The driver installs, but then Windows gives the BSOD when you plug in the DigiSpark.
sprouts
« Reply #9 on: September 06, 2016, 04:42:55 am »
Same problem here.  I bought the sparks from Digistump.  Windows 10 does not recognize them when in CDC mode.   :(
cimba007
« Reply #10 on: September 14, 2016, 11:45:36 am »
*bump* got the same problem ..
catatau
« Reply #11 on: October 09, 2016, 04:52:47 pm »
Same problem here...
« Reply #12 on: October 12, 2016, 02:15:18 am »
tadder
« Reply #13 on: October 18, 2016, 09:57:24 am »
Drivers on WIN 10 PRO
Have tried the updated drivers, as suggested by digistump, and driver now installs with no error  :)
However, the Arduino IDE still cant see the digispark  :(
Like other posters, I have sucessfully loaded sketches using my laptop running Win 10 Home.
The IDE on the home machine is slightly earlier than that on the Pro machine, could this be the issue?
So near, yet so far :'(
tadder
« Reply #14 on: October 22, 2016, 11:26:22 am »
OK I can now report that running 1.6.5 on a USB drive as a portable device in WIN 10 PRO makes no difference (driver still can't see the Digispark). Put the same drive on a WIN 10 Home laptop and it works fine.
Is there anyone out there who has managed to program a Digispark using any version of the Arduino IDE under WIN 10 PRO?
