Author Topic: registering variables at particle.io  (Read 1310 times)
shifaz
« on: May 14, 2016, 04:59:29 am »
Hello,
Any of you guys facing issues registering variable at particle.io?
Sometime after reseting oak, Im unable to get sensor values from particle.io. I noticed that even if the registration is successful the variable doesn't show up on the particle.io API (https://api.particle.io/v1/devices/<device_id>\?access_token=<token>) call response.
please share your experience on this here.
Re: registering variables at particle.io
« Reply #1 on: May 17, 2016, 04:00:43 am »
I had the same issues. I used the Particle CLI tool also, and wouldn't show any registered variables. Without making any changes to the code, the Oak I was using at the time would occasionaly register the variables on Particle, so I really don't know what the story there is. I couldn't get a repeatable test-case that would made it register or not register .
