Author Topic: digiUSB or digiCDC help for a noob on a Digispark? --SOLVED--  (Read 4725 times)
DancesWithRobots
I've managed to get a Digispark working on my Linux box (Mint 17.3).  I'm using Arduino IDE 1.6.8 with the proper board installed.  I can upload sketches and I've even gotten neopixel strandtest to work.
What I can't figure out is how to talk to it.  I've gotten digikeyboard to type out, so I know there must be some sort of serial comm going on.
But when I try to get digiUSB/echo or digiCDC/echo working, I'm at a loss.
Can someone give me a short walk through as to what to do once the sketch is loaded?  I've tried connecting via CuteCom, but I get an error "Could not open /dev/ttyUSB0" when I try to connect.  There must be some fundamental gap in my understanding of this.
Ulitimately, I want to use Python running on a RasPi to send commands to the Digispark to control a Neopixel hanging off of it.  But for now I'll settle for a simple loopback.
« Last Edit: April 15, 2016, 06:40:24 am by DancesWithRobots »
DancesWithRobots
Re: digiUSB or digiCDC help for a noob on a Digispark?
« Reply #1 on: April 15, 2016, 06:36:16 am »
Thank you for your reply.  I got the /dev/tty/USB0 from the bottom of the Arduino IDE which says "Digispark (default 16.5 mhz) on  /dev/ttyUSB0" which is the only way I have of knowing what port is in use since the "port" option under tools is grayed out.  When I first got into Arduino microcontrollers, I used to be able to determine the port under tools, and it was reported as "/dev/TTYS0".  Lately on my newer boards I've been seeing "/dev/ttyACM0" like you said.  BUT--apparently, you are right, because I just tried out  "/dev/ttyACM0" on CuteCom, and it connected.  Sincere gratitude and much of it.  I think I can take it from here.
OBTW, Mint is based on Ubuntu, which is based on Debian (Which you probably knew.)  I prefer the more traditional window and menu layout of Mint, rather than the sidebar thingy on Ubuntu.
Thanks again.
