Please only use this thread for Poll answers. Put your questions or problems in their own thread elsewhere. (You can put a link to your problem thread from your Poll answer here if you want, but please keep this thread clean! Thanks)
POLL - Have you managed to install and use firmware v1.0.0 yet?- Success - It went just fine. = 10 Person & 22 Oaks
- Eventual Success - I got there in the end, but it took some messing around = 19 People & 57 Oaks
- Particle Failure - Firmware installed fine, but having trouble connecting with particle = 7 People & 10 Oaks
- Firmware Failure - I have played around, but still haven't got firmware to install at all = 7 People & 13 Oaks
- Not Tried Yet - I'm waiting for others to test it before I try. = 4 People & 18 Oaks
Total Reports: =
35 People &
120 OaksI wanted to gather an overview of people's experiences with v1.0.0 (eg update v6) in one place, so the community (and Erik) can see at a glance how the new firmware is doing overall. I figured this was best done as a POLL, but it seems I can't post one.
So I will run it as close to a poll as possible using text! Please only answer the main question in this thread (without pouring out your woes!) so we keep the thread clean for assessing people's success / failure with v1.0.0 (just that version please, NOT experiences with v0.9.x in this thread).
I will then try to update the thread with a tally periodically, so we keep track of the changing status.
If you want to reference your experience in more detail, create a separate thread for it, and then put just a link to that thread to more info under your POLL answer.
If you've tried multiple OAKs please give a tally of each: eg Success = 3 OAKs; Firmware Failure = 2 OAKs; Eventual Success = 4 OAKs; Particle Failure = 1 Oak
If you have a future update to change your reply, post it as a new reply, but mark it as an "update", with your new answer, and I'll remove your old answers from the tally, when I next summarise.
Firmware is now officially released.
Update: I've added a new answer "Particle Failure" for those that have the firmware correctly loaded, but having issues connecting to Particle (either at all, or intermittent problems loading a sketch).
To avoid confusion with this new answer, I've also re-named two previous answers:
I changed the title of "Partial Success" to be now called "Eventual Success", which is a better name for people who got there in the end but had some faff in the process (and avoid confusion for those with Particle Issues instead). Hopefully this makes it clear it this option is only for those with a fully working Oak on Particle.
For the same reason, I've renamed "Failure" to be now called "Firmware Failure".
I've done my best to reallocate the answers into these new categories so that the old fail and partial answers no longer contain the Particle Failures. This should hopefully show clearer the distinction between Success: (Either with or without troubles getting there) and Failure: (Either due to Particle Issues or Firmware failed to load).
Thanks.
