Author Topic: Poll of Success/Failure Experiences of v1.0.0  (Read 30498 times)
claudiuo
Re: Poll of Success/Failure Experiences of v1.0.0
« Reply #15 on: March 18, 2016, 02:50:02 pm »
I used the Oak config app (web) not Arduino serial and my results are:
Monday 14:
- Oak 1: first try = success
- Oak 2 and 3 just blinked a few times but no download; tried several times.
Thursday 17 decided to try again: both Oak 2 and 3 worked from first try. Not sure what changed between Monday and Thursday, definitely nothing in my setup, but it worked way better.
So now I'm all set with all 3 Oaks but it took some fiddling with the last 2.
« Reply #16 on: March 19, 2016, 02:00:14 am »
@emardee - I'm not sure if I have confused you by editing and updating my earlier post. Hopefully not! I ended up with 1 x Success, and 4 x Partial Success in the end.
« Reply #17 on: March 19, 2016, 03:40:42 am »
Monday 14:
This is good to hear, and worth noting for those that tried before Thursday - Thursday I updated some settings on the servers to further improve update reliability
avenue33
« Reply #18 on: March 19, 2016, 11:19:43 am »
1 Oak = 1 failure.
I manage to configure the Oak and connect it to my LAN.
But every-time I upload a sketch from the Arduino IDE using Particle OTA, the board never reboots.
Sending file to cloud, to flash myOak (Device ID: xxxxxxxxxxxxxxxxxxxxxxxx) (Device ID: Oak)
Flashing..........................
Rebooting Oak...
Error : Reboot timeout - flash likely failed.
Subsequent tries fail.
Sending file to cloud, to flash myOak (Device ID: d957040101dadd31c5168980)
Flashing...
Error : Flash timeout - flash failed.
Going through Oak WiFi Config again doesn't help. The only solution so far is to perform a factory reset and start again the whole procedure.
« Last Edit: March 19, 2016, 11:37:15 am by avenue33 »
Pegman
« Reply #19 on: March 20, 2016, 03:51:50 am »
Got me 3 Oaks.
On 2 the installation went well.
On 1 it took LOT of tries to connect to it and finally when connected it took three attempts to install 1.0.0 and a few more to claim it with Particle.
After that it was doing the quick-triple-flash thingy and I managed to flash it a few times with some example code. But it's still the black sheep: it cannot connect to Particle anymore and I can't flash it either  :(
Update 26 Mar: today I performed a factory restore (using an Arduino in stead of an FTDI breakout board) without any issues. Afterwards the same behaviour returned:
  • it takes many attempts to connect to the Oak's AP, even though the signal is plenty strong
  • one connected the LED blinks quickly, indicating new firmware is downloaded
  • Oak reboots
  • Error in the Oak Wifi Config page that it cannot establish a connection with the oak
  • retried with the slow update server - same result
From then on the Oak still behaves as an access point but does not allow me to connect to it anymore (using Linux, KDE, Networkmanager app)
Update 2, 26 Mar: Performed the local update (with a Samsung alaxy Tab 2, FWIW) and succeeded at the first try :)
Result:
2 success
1 eventual success
« Last Edit: March 26, 2016, 03:06:35 am by Pegman »
acgt101
« Reply #20 on: March 20, 2016, 06:48:36 am »
i have managed to update the firmware, but have been unable to upload code,says the device is not available on my account.
xaliax
« Reply #21 on: March 20, 2016, 08:50:11 am »
Fail here
2016-03-20 11:44:25 New connection from: 10.0.0.223
2016-03-20 11:44:25 Starting firmware transfer to: 10.0.0.223
2016-03-20 11:45:18 Connection lost to: 10.0.0.223
2016-03-20 11:45:18 Firmware request finished for 10.0.0.223 (Reason: [Failure instance: Traceback: <class 'OpenSSL.SSL.Error'>: [('SSL routines', 'ssl3_read_bytes', 'sslv3 alert bad record mac')]
site-packages\twisted\internet\selectreactor.py:149:_doReadOrWrite
site-packages\twisted\internet\tcp.py:209:doRead
site-packages\twisted\internet\tcp.py:215:_dataReceived
site-packages\twisted\protocols\tls.py:422:dataReceived
--- <exception caught here> ---
site-packages\twisted\protocols\tls.py:360:_flushReceiveBIO
site-packages\OpenSSL\SSL.py:1320:recv
site-packages\OpenSSL\SSL.py:1187:_raise_ssl_error
site-packages\OpenSSL\_util.py:48:exception_from_error_queue
2016-03-20 11:45:18 Early termination to: 10.0.0.223 (530432 bytes written, fail count = 1)
2016-03-20 11:45:18 Finishing firmware transfer to: 10.0.0.223 (1 transfers done)
SteveT
« Reply #22 on: March 20, 2016, 09:27:10 am »
1 Oak : Success!
I had a lot of problems trying to do it on my work laptop, but I think IT has something blocked. I tried it on my home computer and it worked first time. Whoopee!
« Last Edit: March 26, 2016, 05:15:38 pm by SteveT »
gharris012
« Reply #23 on: March 20, 2016, 09:42:51 am »
Partial Success.
I got my oak online, but both the main update server and the backup/slower server did not work. I used the local update server and that worked the first time.
I had no problems getting the device connected to my network (though my first connection to the softAp took a long time to go through), or my particle account.
The first sketch upload from the Arduino IDE threw the "Oak is back online before flash sucessful." error. I read through this post and a couple other threads and didn't see an obvious solution or explanation, so I just tried it again twice and it worked both times. I'll chalk it up to cosmic rays.
A couple bumps in the road, but nothing too serious.
Z69
« Reply #24 on: March 20, 2016, 01:05:35 pm »
Partial something...
I have two Oak's and updating the firmware went without a problem, i am just unable to upload any code to them
« Last Edit: March 20, 2016, 01:48:49 pm by Z69 »
mfelling
« Reply #25 on: March 20, 2016, 03:37:33 pm »
1 Oak = FAILURE after Hours of attempts and following forums, multiple Wi-Fi networks. Will see other networks will never connect to them
emardee
« Reply #26 on: March 20, 2016, 09:43:11 pm »
Note the changed permissible answers for added clarity!
POLL - Have you managed to install and use firmware v1.0.0 yet?
  • Success - It went just fine. = 6 Person & 11 Oaks
  • Eventual Success - I got there in the end, but it took some messing around = 3 People & 15 Oaks
  • Particle Failure - Firmware installed fine, but having trouble connecting with particle = 8 People & 11 Oaks
  • Firmware Failure - I have played around, but still haven't got firmware to install at all = 4 People & 4 Oaks
  • Not Tried Yet - I'm waiting for others to test it before I try. = 2 People & 20 Oaks
Total Reports to date (including up to mfelling above): = 18 People & 61 Oaks
Update:
I've added a new answer option "Particle Failure" for those that have the firmware correctly loaded, but having issues connecting to Particle (either at all, or intermittent problems loading a sketch).
To avoid confusion with this new answer, I've also re-named two previous answers:
I changed the title of "Partial Success" to be now called "Eventual Success", which is a better name for people who got there in the end but had some faff in the process (and avoid confusion for those with Particle Issues instead). Hopefully this makes it clear it this option is only for those with a fully working Oak on Particle.
For the same reason, I've renamed "Failure" to be now called "Firmware Failure".
I've done my best to reallocate the answers into these new categories so that the old fail and partial answers no longer contain the Particle Failures. This should hopefully show clearer the distinction between Success: (Either with or without troubles getting there) and Failure: (Either due to Particle Issues or Firmware failed to load).
Thanks.
nelsonsilvafilho
« Reply #27 on: March 21, 2016, 05:42:27 pm »
Total failure and regret of doing the FORCED update 😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡😡
stoneburner
« Reply #28 on: March 22, 2016, 04:24:45 am »
Firmware Failure = 5 Oaks
does anyone know if its possible to flash the oaks into a "normal" esp8266 ?
nelsonsilvafilho
« Reply #29 on: March 22, 2016, 05:13:04 am »
+1
