Author Topic: overcome pull-up on p3 to use mosfet driver board  (Read 3378 times)
ligi
« on: February 10, 2016, 04:52:41 pm »
I have a MOSFET Driver board attached to the digistump - it works fine for P0..P2 - unfortunately I have a problem with P3 - in the docs I was reading:
Pin 3 (P3) has a 1.5 kΩ pull-up resistor attached to it which is required for when P3 and P4 are used for USB communication (including programming). Your design may need to take into account that you'd have to overpower this to pull this pin low.
unfortunately I don't know how to overcome this pull-up resistor - I am better with code than with electronics ;-)
this is the MOSFET board:
https://www.pollin.de/shop/downloads/D810329B.PDF
any pointers on how to overcome the resistor?
context: will be for this project https://github.com/ligi/BlowerControl
« Last Edit: February 10, 2016, 06:48:15 pm by ligi »
ligi
Re: overcome pull-up on p3 to use mosfet driver board
« Reply #1 on: February 11, 2016, 11:31:39 am »
Thanks - it was a wiring error and I thought it came from the pull-up - works fine now ;-)
