Author Topic: Use a 1.8'' TFT with Digispark  (Read 5719 times)
brunosso
« on: January 29, 2016, 09:14:42 am »
Hello!! i found this thread but i don't understand how to connect the TFT to Digispark!
https://digistump.com/board/index.php?topic=1122.0
someone can help me?
postuma
Re: Use a 1.8'' TFT with Digispark
« Reply #1 on: February 05, 2016, 01:08:28 pm »
I did this for my bike computer - http://digistump.com/board/index.php/topic,1938.0.html - not the identical TFT screen but almost the same, and may use the same pinout.
I used the TFT library that's part of the Arduino IDE. See File > Examples > TFT. Pin definitions I used:
#define cs   9                                //pin definitions for TFT screen
#define dc   6
#define rst  7
but you could or even may need to hook it up differently. Check the data sheet/schematics to make sure you make the right connections - MISO to MISO, SCK to SCK, MOSI to MOSI, GND to GND, BL and +5V to 5V VCC, and LCD DS, LCD D/C, and Reset to whichever pins you defined above.
Hope this helps. Good luck
