Author Topic: Warning: device with unknown new version of Micronucleus detected.  (Read 14651 times)
magnets
So i'm running ubuntu 64 bit.
i have arduino 1.6.5 and followed the wiki instructions on supporting the digispark pro through arduino.
when i try and upload i get the following error
Device reports version as: 2.0
This tool doesn't know how to upload to this new device. Updates may be available.
i had a good google and have tried the following:
I have ensured i am in the dial out group
i read this post which stated it might be a old version of micronucleus
http://digistump.com/board/index.php?topic=1673.0
however when i do the same query i only get
./home/bob/.arduino15/packages/digistump/tools/micronucleus
./home/bob/.arduino15/packages/digistump/tools/micronucleus/2.0a4/micronucleus
so i though maybe my one isn't the right one
as per this post https://digistump.com/board/index.php?topic=1693.0
but i tried the micronucleus attatched to that post and that didin't work either
i tried installing the 32 bit version of libusb via this post
http://askubuntu.com/questions/311401/libusb-0-1-so-4-shared-lib-error-in-ubuntu-64-bit-system
but that also didn't help
i've added the udev rules
i've rebooted
i'm out of ideas...
any help would be greatly appreciated.
Ralf
  • Guest
Re: Warning: device with unknown new version of Micronucleus detected.
« Reply #1 on: August 11, 2015, 01:49:50 am »
I am not familiar which Ubuntu 64 bit, but it sounds as if you have an old version of micronucleus in your path. You may try it with "which micronucleus" on the command line.
The Digispark Pro uses a 2.x firmware, because the 1.x version does not support the ATtiny 167. But the Digistump PC software package delivers the 2.x micronucleus commandline tool, which is downwards compatible to the 1.x firmware of the ATtiny85. I think the switch was with the change from Digistump Arduino 1.0.4 to 1.5.8.
Ralf
magnets
« Reply #2 on: August 11, 2015, 03:43:01 am »
thanks for the response Ralf!
i tried that command, at the home level, and in the tools folder (i'm fairly new to linux) and as sudo but everytime i get no response
bob@Slaptop:~/.arduino15/packages/digistump/tools$ which micronucleus
i found this post, which seems to agree with your theory, though when i run the suggested fix i don't have an old version
bob@Slaptop:~/.arduino15/packages/digistump/tools$ sudo su
root@Slaptop:/home/bob/.arduino15/packages/digistump/tools# cd /
root@Slaptop:/# find -name "micronucleus"
./home/bob/Downloads/micronucleus
./home/bob/.local/share/Trash/files/micronucleus
root@Slaptop:/#
Ralf
  • Guest
« Reply #3 on: August 11, 2015, 05:02:31 am »
Well,
that's funny. The error is typical for an 1.x commandline tool meeting the 2.x firmware. if there was a library missing, you would get a totally different error.
Is the version in the 2.0.4 folder really a 2.x version?
You could try to call it directly on a commandline: change into its folder
cd ~/.arduino15/packages/digistump/tools/micronucleus/2.0a4
and submit a
./micronucleus --help
The last line of the output should be:
Commandline tool version: 2.0a4
Ralf
magnets
« Reply #4 on: August 11, 2015, 08:22:26 pm »
thanks for the help, i followed your advice but i'm more confused than ever
it says command not found.
bob@Slaptop:~/.arduino15/packages/digistump/tools/micronucleus/2.0a4$ micronucleus --help
micronucleus: command not found
bob@Slaptop:~/.arduino15/packages/digistump/tools/micronucleus/2.0a4$ ls
launcher  micronucleus
bob@Slaptop:~/.arduino15/packages/digistump/tools/micronucleus/2.0a4$ cd micronucleus
bash: cd: micronucleus: Not a directory
using nautilus i've checked that both launcher and micronuclues are read write for everyone and ticked the box that says allow executing file as program.
Ralf
  • Guest
« Reply #5 on: August 12, 2015, 12:14:37 am »
the command is not
micronucleus --help
but
The "./" tells the shell that it has to search in the actual folder, without it it searches in the path.
Ralf
magnets
« Reply #6 on: August 15, 2015, 03:28:28 pm »
thanks for the tip!
sorry for the delay in coming back to you. sick pet.
i don't get that output! so i'm assuming i don't have version 2, i'm going to see if i can get it now
i get this
bob@Slaptop:~/.arduino15/packages/digistump/tools/micronucleus/2.0a4$ ./micronucleus --help
usage: micronucleus [--run] [--dump-progress] [--type intel-hex|raw] [--no-ansi] [--timeout integer] [--erase-only] filename
  --type [intel-hex, raw]: Set upload file type to either intel hex or raw
                           bytes (intel hex is default)
          --dump-progress: Output progress data in computer-friendly form
                           for driving GUIs
             --erase-only: Erase the device without programming. Fills the
                           program memory with 0xFFFF. Any files are ignored.
                    --run: Ask bootloader to run the program when finished
                           uploading provided program
                --no-ansi: Don't use ANSI in terminal output
      --timeout [integer]: Timeout after waiting specified number of seconds
                 filename: Path to intel hex or raw data file to upload,
                           or "-" to read from stdin
so i'll try and get the correct output on the command line then post back my results
magnets
« Reply #7 on: August 15, 2015, 04:02:53 pm »
ok, as you can see i'm not super good on linux, but this is what i did
i went to the micronucleus site
https://github.com/micronucleus/micronucleus
and i hit download zip (right hand side near the bottom)
then i extracted the zip to a temporary folder.
and using the command shell (?) i navigated to the folder and got it to list it's contents
bob@Slaptop:~/Downloads/temp/micronucleus-master/commandline$ ls
49-micronucleus.rules  builds  library  Makefile  micronucleus.c  Readme
then i ran the make command
bob@Slaptop:~/Downloads/temp/micronucleus-master/commandline$ make
Building library: micronucleus_lib...
gcc  -L/usr/lib/x86_64-linux-gnu -lusb -Ilibrary -O -g -D LINUX -c library/micronucleus_lib.c
Building library: littleWire_util...
gcc  -L/usr/lib/x86_64-linux-gnu -lusb -Ilibrary -O -g -D LINUX -c library/littleWire_util.c
Building command line tool: micronucleus...
gcc  -L/usr/lib/x86_64-linux-gnu -lusb -Ilibrary -O -g -D LINUX -o micronucleus micronucleus.c micronucleus_lib.o littleWire_util.o -L/usr/lib/x86_64-linux-gnu -lusb
then using nautilus i went to the
folder, and then renamed the current micronucleus as micronucleus.old and pasted in the new micronucleus that the makefile created
now when i run the help i get
usage: micronucleus [--help] [--run] [--dump-progress] [--fast-mode] [--type intel-hex|raw] [--timeout integer] [--erase-only] filename [--no-ansi]
                           for driving GUIs
              --fast-mode: Speed up the timing of micronucleus. Do not use if
                           you encounter USB errors.
Commandline tool version: 2.0a5
Success!!
in the arduino ide, i try to upload an example
Sketch uses 936 bytes (6%) of program storage space. Maximum is 14,844 bytes.
Running Digispark Uploader...
> Device is found!
connecting: 16% complete
connecting: 22% complete
connecting: 28% complete
connecting: 33% complete
> Device has firmware version 2.0
> Device signature: 0x1e9487
> Available space for user applications: 14970 bytes
> Suggested sleep time between sending pages: 7ms
> Whole page count: 234  page size: 64
> Erase function sleep duration: 1638ms
parsing: 50% complete
> Erasing the memory ...
erasing: 55% complete
erasing: 60% complete
erasing: 65% complete
> Starting to upload ...
writing: 70% complete
writing: 75% complete
writing: 80% complete
> Starting the user app ...
running: 100% complete
yaaaaaaaaaaaaaaaaaaaaaay
Thanks Ralf!
the only thing i can assume is the digistump arduino script pulled the wrong version of micronucleus (maybe version 2 for 32 bit?) then, because i don't understand Make, i grabbed a wrong version of  micruncleus which gave the strange error
for others following along, you'll need to put the udev rules in to get this to work without sudo
Ralf
  • Guest
« Reply #8 on: August 16, 2015, 06:51:03 am »
That's Fine.
I also suspected, that the micronucleus shipped by digispark may be a 32bit one.
Ralf
panguitou
« Reply #9 on: January 15, 2016, 07:42:20 am »
Thank you Magnet !
I was meeting exactly the same problem than you and I followed your excellent method to re-compile micronucleus and now it worked perfectly !
I had the same problem with my old Digispark and it also settled the problem !
You know what ?
 ;D :D
dfp
« Reply #10 on: February 08, 2016, 11:47:10 pm »
Compiling had a problem with a missing dependency:
> make
make: libusb-config: Command not found
gcc   -Ilibrary -O -g -D LINUX -c library/micronucleus_lib.c
In file included from library/micronucleus_lib.c:30:0:
library/micronucleus_lib.h:35:80: fatal error: usb.h: No such file or directory
   #include <usb.h>        // this is libusb, see http://libusb.sourceforge.net/
compilation terminated.
Makefile:49: recipe for target 'micronucleus_lib' failed
make: *** [micronucleus_lib] Error 1
Per this note: http://askubuntu.com/questions/503928/missing-usb-h-file-what-is-it-where-do-i-get-it
the solution was:
sudo apt-get install libusb-dev
That got me a clean compile. Don't know yet if I'm going to get a usable micronucleus or not ...
kjubow
« Reply #11 on: September 03, 2017, 01:38:51 pm »
Can anyone help me??
I don't exactly understand that part : "home/bob/.arduino15/packages/digistump/tools/micronucleus
folder, and then renamed the current micronucleus as micronucleus.old and pasted in the new micronucleus that the makefile created"
Can you explain it to me ??
« Reply #12 on: September 04, 2017, 03:17:59 am »
Welcome to the forum kjubow! ;)
What 'magnets' did was basically:
  • Download/clone the source code for micronucleus from https://github.com/micronucleus/micronucleus
  • Unzip the file, and navigate to the location of the unpacked files in a terminal window
  • Once he was in that folder, ran the 'make' command to compile the micronucleus executable
  • He then copied the resulting executable to his /home/username/.arduino15/packages/digistump/tools/micronucleus directory, renaming the old file first
  • And then tested it to make sure it worked as expected
First thing is first... are you on linux? As this was specific to linux (and a Ubuntu/Debian flavour of linux at that).
And secondly, how familiar with linux are you? (I'm guessing not very if you don't recognise the /home path - but that's ok - just need to know the baseline from which to provide instructions)
kjubow
« Reply #13 on: September 11, 2017, 11:33:10 pm »
Yes, im running ubuntu. Thanks for reply ;)
