Author Topic: Bootloader is corrupted  (Read 4358 times)
Geetanjali
« on: June 10, 2014, 12:34:09 am »
Hey i am using attiny85 board in that  i want reset pin as i/o for that i change fuse setting to make reset pin enable which can make reset pin as i/o, but after so many time using board my boot-loader get corrupted n because of that i cnt even upload program. even again i try to dump bootloader  in board i have getting message.
"avrdude_original: please define PAGEL and BS2 signals in the configuration file for part ATtiny85" kindly please tell me why is this happening  :(
Re: Bootloader is corrupted
« Reply #1 on: June 10, 2014, 01:13:02 am »
WRONG FORUM! PLEASE MOVE
The DigiX has no bootloader!
It looks like, that you also don't use a digispark. So you need to describe in detail
  • which board you are using,
  • which settings you use in the IDE,
  • which programmer you are using,
  • which bootloader etc.
If you take some time, you will find many threads describing the attiny-boot and programming issues!
« Last Edit: June 10, 2014, 01:16:45 am by gogol »
