Author Topic: RF24 "GettingStarted" and "led_remote" example tweaks  (Read 3379 times)
tkbay
« on: February 01, 2014, 07:41:47 pm »
FYI, I had to tweak two of the RF24 example programs
to get them to work correctly:
In "GettingStarted",  the program defaults to "role_pong_back"
(receive and echo) mode, but the radio.openReadingPipe() is
set up for the "role_ping_out" mode.
To get the default role and pipe to match up you can change this:
  //if ( role == role_ping_out )
    //radio.openWritingPipe(pipes[0]);
    radio.openReadingPipe(1,pipes[1]);
  //else
    //radio.openWritingPipe(pipes[1]);
    //radio.openReadingPipe(1,pipes[0]);
to this:
   // radio.openReadingPipe(1,pipes[1]);
  //else
In "led_remote", I had to wrap the radio.write() call
inside radio.stopListening() and radio.startListening() calls
for any of the sent messages (except occasionally the first one)
to get through to the receiving unit:
      p("Now sending...");
      radio.stopListening();
      bool ok = radio.write( button_states, num_button_pins );
      radio.startListening();
      if (ok)
