Author Topic: [SOLVED] Wifi Stuck On "Starting"  (Read 3178 times)
Asvaldr
« on: January 26, 2014, 11:16:38 pm »
Hi All,
Just started with my DigiX and i did get the wifi up and running while i was porting the MySql Arduino connecter (i'll post the lib once i'm done). But now the wifi is just stuck on starting.
  • Running the basic ping example.
  • My Digix is configured in AP+STA.
  • I even tried restoring it, but granted i put the same settings back because they did work up until this morning. But after coming back later, it started working again... now its not coming good.
  • I'm connected to my WiFi since it has been assigned an IP by my router and when i log in to the digix AP; it gives me signal strength and the same assigned ip.
  • Found a vague previous post http://digistump.com/board/index.php/topic,1224.msg5427.html#msg5427 but that just says to me he may have reset like i already did?
I'd really appreciate any help anyone can provide.
Thanks in advance
« Last Edit: January 29, 2014, 03:39:17 am by Asvaldr »
balin
Re: Wifi Stuck On "Starting"
« Reply #1 on: January 27, 2014, 04:10:56 am »
This speed wifi.begin(115200); and this one must match!
« Last Edit: January 29, 2014, 03:27:08 am by balin »
Asvaldr
« Reply #2 on: January 29, 2014, 01:47:30 am »
Thanks for the reply; so you mean you use "Serial.begin(9600)" and have the setting in the Wifi as 115200?
If so mine is already set to those....
Any other ideas anyone?
« Last Edit: January 29, 2014, 01:51:22 am by Asvaldr »
balin
« Reply #3 on: January 29, 2014, 03:25:45 am »
no wifi.begin(115200); must match with the one you see on the site!!!!!!!!!   serial.begin(); is only for you and your pc. but in wifi.begin(); you set the speed for the controller to speak with the Wifi module. So both wifi module and wifi.begin() must be equal!
Asvaldr
« Reply #4 on: January 29, 2014, 03:38:40 am »
That's certainly fixed it. I got too focussed on why it would have worked then not.
Now I think it occurred when I used the on-board reset. Anyhow; thank you for the assistance.
