Author Topic: Micro SD card slot specs  (Read 3048 times)
tkbay
« on: January 11, 2014, 03:29:32 pm »
Hi all -
What kinds of cards are compatible with the Micro SD card slot?  SD/SDHC/SDXC?
Are there any memory size or speed class rating limits?
Thanks
Re: Micro SD card slot specs
« Reply #1 on: January 11, 2014, 04:49:21 pm »
Any card that can work in SPI mode (backwards compatible MMC mode) - which rarely stated on the card - but generally most cards do. All SD should - SDHC/SDXC don't have to but more often than not seem to.
Memory size support would be a function of the library you are using - I imagine most support up to 32gb minimum.
Speed doesn't play much of a role since we are using the SPI protocol to access them
erix
« Reply #2 on: January 19, 2014, 10:54:46 am »
I have an additionnal question about the cards we can use in the SD card slot.
what kind of format must we use? fat etc etc?
Thanks in advance
Regards
Erix
« Reply #3 on: January 19, 2014, 10:02:45 pm »
That is completely up to the library you are using - see the arduino reference for the built in library here: http://arduino.cc/en/Reference/SD
