Author Topic: DigiX Pinout documentation  (Read 52415 times)
Re: DigiX Pinout documentation
« Reply #30 on: January 27, 2014, 08:57:00 am »
0.6.2 added to the initial post.
Additions:  JTAG and Ethernet-PHY Pins marked
« Reply #31 on: February 10, 2014, 07:12:29 am »
attached Version 0.7 to the very first post
  • corrected PWM4 assigment
  • added reason for crossconnected pins
  • added PC0 information to ERASE
  • added AD15 information about temp sensor
« Last Edit: February 10, 2014, 07:15:12 am by gogol »
« Reply #32 on: February 27, 2014, 07:08:24 am »
attached Version 0.8 to the very first post.
  • Information of Wifi-Modul
  • JTAG-pins of Wifi module marked
  • design changes
« Reply #33 on: March 07, 2014, 08:50:01 am »
attached Version 0.9 to the very first post.
  • added solder jumper information, location, name, purpose, default setting
tastewar
« Reply #34 on: March 07, 2014, 07:58:15 pm »
Thanks for all this! One quick question from glancing at the doc. You state:
UART TX1 connected to WiFI RX (WiFi-P39)
UART RX1 connected to WiFI RX (WiFi-P41)
Shouldn't one of those say WiFI TX (I'm guessing UART RX1)
« Reply #35 on: March 09, 2014, 01:49:09 am »
Thanks for pointing that out!  I fixed it and uploaded a version 0.9.1 to the very first page!
@All users of this diagram: Whenever you see unclear/wrong/missing information, drop a short note here!  Quality can only be reached, when more eyes are watching!
DigiX Pinout documentation 0.9.5
« Reply #36 on: March 20, 2014, 04:30:01 am »
Attached version 0.9.5 to the very first post.
Changes:
  • minor layout corrections
  • wifi enable-jumper
  • on-board LED
  • form-fields for pin annotations
The biggest change is almost hidden: When opening with Adobe Reader click to "Highlight Existing Fields" in the top-right corner.
I have embedded text fields to almost every pin, which is invisible, as long as no information is entered.
However, as soon, as you enter your own project depending description, the text-field is visible and covers the basic pin information.
When you delete content of such an text field, the field disappears again.
« Last Edit: March 20, 2014, 04:36:18 am by gogol »
DigiX Pinout documentation: YOUR FEEDBACK ?
« Reply #37 on: March 24, 2014, 02:31:14 am »
Has someone tried the form fields for own project documentation?
Is that usable or just my own nerdy idea?
How are you documenting own projects, which have a lot of connections?
« Reply #38 on: May 12, 2014, 06:28:29 am »
Attached version 0.9.7 to the very first post.
  • minor layout changes
  • added eeprom
Anybody here, who is really using this?
« Reply #39 on: May 12, 2014, 09:41:46 pm »
I use it constantly!
And the wiki page with a copy of it (which I will update now) is one of the most accessed.
Thanks for maintaining this!
« Reply #40 on: May 16, 2014, 11:48:26 pm »
good+=1
« Reply #41 on: May 19, 2014, 01:13:19 am »
Feedback is always welcome. From my point of view, it should be now almost complete to leave the "beta" phase. However I am not sure, if there are still some quirks, cut&paste errors or other problems.
Getting an idea, how many users haven't seen any mistake during their use, will also help.
« Reply #42 on: May 26, 2014, 01:07:19 am »
Attached version 0.98 to the very first post!
Added information, that DigiX-pins are 3.3V only.
kd7eir
« Reply #43 on: May 30, 2014, 08:40:26 am »
Thank you for the update and for all the incredibly hard work you put into maintaining this great resource.
« Reply #44 on: June 10, 2014, 01:03:06 am »
Updated the version, included buck-regulator information from thread: http://digistump.com/board/index.php/topic,1432.0.html
See first post in this thread!
