Author Topic: Abort Mission, -1 error  (Read 27253 times)
MoFoQ
« on: December 31, 2012, 03:46:57 pm »
Originally, I too had the res >= 4 issue (which was solved with udev rules listed here; on a side-note, I think it should be placed in the "Connecting" tutorial).
Anyways, now I get the dreaded "Abort mission! -1 error has occured ..."
Binary sketch size: 756 bytes (of a 6,010 byte maximum)
Running Digispark Uploader...
Plug in device now...
> Device is found!
connecting: 40% complete
> Device looks like ATtiny85!
> Whole page count: 94
parsing: 60% complete
> Erasing the memory ...
erasing: 79% complete
I've tried 6 different sparks and 2 different direct USB ports (not off a hub).
I'll try it on Windows in a bit.
Any thoughts/ideas?
« Last Edit: December 31, 2012, 03:46:57 pm by MoFoQ »
willscott
« Reply #1 on: December 31, 2012, 04:29:22 pm »
I also get this.  For me, the underlying libusb error was -EILSEQ, which it looks like means either there was a timeout, or a bad checksum on the response.
My spark works on my mac, so I\'m pretty sure has something to do with linux & the linux usb driver / libusb setup.
MoFoQ
« Reply #2 on: December 31, 2012, 07:18:18 pm »
Hmm...that wasn\'t it either; I thought it might be that I needed to have micronucleus\'s uploader be executed with root privileges after reading the README for it so I edited and recompiled the avr-dummy to use sudo but it didn\'t seem to change anything...still got the error.
probono
« Reply #3 on: January 01, 2013, 01:58:47 pm »
With my selfmade Digispark compatible breadboard circuit I got this as well. Had to try about 10 times until it succeeded. Seems like \"something\" (timing? voltage? software?) is not 100% reliable.
« Last Edit: January 01, 2013, 01:59:17 pm by probono »
MoFoQ
« Reply #4 on: January 01, 2013, 04:30:13 pm »
It\'s starting to look like it might be an issue with the uploader on Linux as I was able to get it to work just fine under Windows.
Is there a debug version of it so I can post debug results?
probono
« Reply #5 on: January 01, 2013, 04:38:38 pm »
I was using Linux as well... Ubuntu 12.10, Quantal Quetzal
« Reply #6 on: January 01, 2013, 07:18:33 pm »
@MoFoQ - you can try an upload of the either of the hex files in the micronucleus repository using just the micronucleus command line app: https://github.com/Bluebie/micronucleus-t85/tree/master/commandline
That might help you debug, and then you can compile the commandline app with any options you\'d like.
For the record this works for me on 12.04 Ubuntu - but I won\'t claim to be a linux expert and would appreciate anything you or anyone else discovers.
Macjbraun
« Reply #7 on: January 02, 2013, 03:56:39 pm »
Try with a hub with no other USB devices plugged in the hub. Worked for me.
MoFoQ
« Reply #8 on: January 03, 2013, 12:23:06 pm »
@digistump, are you referring to \"cdc232.hex\" and \"littleWire_v11.hex\"?
note, I\'m using 10.04 LTS on this machine, 12.04 on another.
And it doesn\'t seem to like using a USB hub (it doesn\'t even detect it being inserted)
« Reply #9 on: January 03, 2013, 12:51:38 pm »
@MoFoQ - yes those or any other hex file- basically I\'m just suggesting that you try using micronucleaus directly so you can test with it directly instead of through the Arduino IDE
A few questions:
Is the machine you had it worked successfully on with windows the same machine as one of the linux ones?
Are the linux machines it is not working on laptops or desktops? If desktops have you tried the USB ports on the back with no extension cable?
I\'ll be uploading some linux builds today and I\'ll do a fresh load of 12.04 and see if I can duplicate it (haven\'t been able to duplicate it yet).
Thanks for sticking with me on troubleshooting this!
MoFoQ
« Reply #10 on: January 03, 2013, 08:32:24 pm »
it\'s very odd how it works (it might be a permissions thing)
from now on, I will refer to the computers as Computer A and Computer B.
Computer A runs 10.04 only
Computer B runs Win7 and 12.04
Comp A output via micronucleus (non-root):
$ ./micronucleus --run cdc232.hex
> Device is found!
connecting: 33% complete
parsing: 50% complete
erasing: 66% complete
Comp A output via micronucleus (root):
# ./micronucleus --run cdc232.hex
> Device is found!
Comp B (12.04) output from arduino IDE (non-root):
> Device is found!
erasing: 80% complete
> Starting to upload ...
writing: 80% complete
>> Abort mission! An error has occured ...
Comp B (12.04) output from arduino IDE (root):
> Device is found!
writing: 100% complete
Comp B (12.04) output from micronucleus (non-root):
> Device is found!
writing: 83% complete
> Starting the user app ...
running: 100% complete
Comp B (12.04) output from micronucleus (root):
> Device is found!
Comp B (12.04) summary:
arduino IDE (non-root): FAIL
arduino IDE (root): PASS
micronucleus (non-root): PASS
micronucleus (root): PASS
« Last Edit: January 03, 2013, 08:33:19 pm by MoFoQ »
MoFoQ
« Reply #11 on: January 03, 2013, 08:36:06 pm »
forgot to answer your questions about laptops and desktops.
Comp A is a desktop and I used the direct USB ports as well (front, back, etc.)
Comp B is a laptop.
I haven\'t had any issues under Windows 7 and under linux, it looks like micronucleus doesn\'t have an issue.
(though I did notice that if I used \"660\" as listed in the \"res > = 4\" fix, it would not detect insertion; I use \"666\" instead...yes...dreadfully evil :D )
Emerica
« Reply #12 on: January 03, 2013, 08:39:14 pm »
Having this problem as well.
I\'ve tried multiple ports directly, through some extensions. 3 sparks.
Into a usb3 hub plugged into a usb2 port was a no go at all.
Ubuntu 12.04
> Device is found!
connecting: 20% complete
connecting: 23% complete
connecting: 27% complete
connecting: 30% complete
connecting: 34% complete
parsing: 40% complete
erasing: 60% complete
[---------------------60 to 79%-----------------------]
« Reply #13 on: January 03, 2013, 08:56:15 pm »
@Emerica - have you tried running it as root?
Emerica
« Reply #14 on: January 03, 2013, 09:08:39 pm »
Yes, same deal. Either using sudo or sudo su and then trying, no go.
Followed the guide as well as:
/etc/udev/rules.d/49-digispark.rules
SUBSYSTEMS==\"usb\", ATTRS{idVendor}==\"16d0\", ATTRS{idProduct}==\"0753\", MODE:=\"0666\"
KERNEL==\"ttyACM*\", ATTRS{idVendor}==\"16d0\", ATTRS{idProduct}==\"0753\", MODE:=\"0666\", ENV{ID_MM_DEVICE_IGNORE}=\"1\"
