Author Topic: Fritzing breadboard image of through hole shield  (Read 5233 times)
MichaelMeissner
« on: August 16, 2012, 06:59:29 am »
I decided to make a fritzing of how I think the shield is laid out to give me an idea of how to place the components.  Hopefully it is helpful to others.  Of course if the official layout fzz is available, you won't need this one.
http://www.the-meissners.org/arduino/digispark-throughhole-2012-08-16.fzz
http://www.the-meissners.org/arduino/digispark-throughhole-2012-08-16.png
« Last Edit: August 16, 2012, 06:59:29 am by MichaelMeissner »
sparr
« Reply #1 on: August 16, 2012, 01:55:20 pm »
Be careful making projects based on this, the final board might be different!
MichaelMeissner
« Reply #2 on: August 16, 2012, 04:38:42 pm »
Yes of course.  In fact, the position of the pins has already changed today after I posted this.  But I wanted to get a rough estimate if my proposed setup would work on the through hole shield.  It is going to be tight, and I will probably have to look up opto-isolators that only have 4 pins instead of the ones with 6 pins that I\'m currently using.
« Last Edit: August 16, 2012, 04:41:30 pm by MichaelMeissner »
« Reply #3 on: August 24, 2012, 05:47:14 pm »
Move the 5v vin gnd pins over two the left and you\'ll have it close enough for use with fritzing!
jetdillo
Re: Fritzing breadboard image of through hole shield
« Reply #4 on: January 24, 2013, 06:27:46 pm »
Has there been any further work done on this or should I go ahead and do one myself ?
I made a project w/ my new Digispark boards over the weekend that I'd like to turn into a shield and it would be great to have a proper Fritzing part instead of just a perfboard part.
MichaelMeissner
« Reply #5 on: January 25, 2013, 01:07:24 pm »
Do one yourself.  I was doing it initially, because there wasn't a picture of how the pins were laid out, and since I did it, they changed where the power/vin pins are to be more breadboard friendly.
