Author Topic: Driver Issues  (Read 3077 times)
TylerFricks
Driver Issues
« on: September 13, 2013, 01:52:05 pm »
I've seen issues with unsigned drivers, but I happen to have a signature from microsoft that I signed it with. However my issue is with the driver itself. It seems that in order to upload anything past the first upload, it will only go to 55 percent then error out of the UL. I would really like to know how to fix this because of the aspect that it is a hassle and it takes a really long time. Thanks for the DigiX but please help!
P.S. I tried the Erase/Reset method, to no avail.
Re: Driver Issues
« Reply #1 on: September 13, 2013, 03:01:34 pm »
Tyler - can you try a different usb cable if you haven't yet? This sounds like a USB timing issue, nothing like this has been reported yet, but I've seen it with the Digispark.
Also can you try programming it as an Arduino Due (Native Port) and see if you have the same issue?
TylerFricks
Re: Driver Issues
« Reply #2 on: September 13, 2013, 06:22:16 pm »
Thanks Erik! It seems the shorter the cable, the better. Problem resolved.
Moderator: End Thread
