Author Topic: DigiFi Library with AT command Wrappers  (Read 9092 times)
ags131
« on: September 10, 2013, 02:01:09 pm »
Hello, I've added wrapper functions for all the wifi AT commands to the DigiFi library and thought I would share.
Not all have been tested so there may be bugs. Also, the UartAutoFrame commands are not implemented as I severely dislike very long function names and havent figured out descriptive short names yet.
Also, as a note, readConfig does NOT currently work. it hangs in readResponse and requires a hardware reset to recover. (Infinite Loop probably). Running the raw AT command does work. It may need some custom output handling instead of relying on readResponse.
I will be submitting a pull request with these changes once the GitHub is up, for now they are posted here for the other beta backers who are eager to work with WiFi.  ;)
https://copy.com/WzsDHg0y8JVGxhWM
Re: DigiFi Library with AT command Wrappers
« Reply #1 on: September 11, 2013, 12:11:57 am »
DigiFi library is now on github: https://github.com/digistump/DigiFi - send those commits! prize to the first person to truly solve the intermittent issues with timing out/not getting the response (see wiki)!
