Author Topic: 3.3v powered  (Read 3487 times)
tunahammer
3.3v powered
« on: August 20, 2013, 11:42:00 am »
I noticed
Inline image 1
and am making a board that was based on the Due, which seemed to have problems powering the whole board via this pin. Does this really mean I can power the whole board with just this pin?
I'll be using a TRACO TSR-1 device [size=78%]http://www.adafruit.com/datasheets/tsr1.pdf[/size]
Re: 3.3v powered
« Reply #1 on: August 20, 2013, 12:24:10 pm »
The image didn't come through - but with the DIgiX everything on the board except USB-OTG will work when powered at 3.3v via the 3.3v pin. In addition the 5v pin can be powered by 3.7-5.5v and everything will work as well (except USB-OTG if under 4.7v)
Re: 3.3v powered
« Reply #2 on: August 20, 2013, 12:24:55 pm »
To clarify - everything on the board will work except USB-OTG but the 5v pins will not be powered - so a shield or circuit that depends on them will not work
