Author Topic: DigisparkSoftSerial - error on compile  (Read 7453 times)
yair
« on: May 17, 2013, 01:21:30 pm »
In file included from SoftSerialExample.ino:23:
C:\bin\Digispark-Arduino-1.0.4\libraries\DigisparkSoftSerial/SoftSerial.h:44:44: error: ../TinyPinChange/TinyPinChange.h: No such file or directory
SoftSerialExample.ino: In function 'void setup()':
SoftSerialExample:32: error: no match for 'operator!' in '!Serial'
SoftSerialExample.ino:32: note: candidates are: operator!(bool) <built-in>
yair
Re: DigisparkSoftSerial - error on compile
« Reply #1 on: May 17, 2013, 01:41:52 pm »
changed line in header to reflact corrrect folder structure
#include "../DigisparkTinyPinChange/TinyPinChange.h"
and get just this
« Reply #2 on: May 17, 2013, 02:18:21 pm »
What code are you trying to compile? The path issue is know and will be fixed in the next release - but I have no issue once I fix that
Also this works:
#include <TinyPinChange.h>
yair
« Reply #3 on: May 17, 2013, 02:53:02 pm »
thanks for the replay
example was SoftSerialExample.ino
yair
« Reply #4 on: May 17, 2013, 10:51:21 pm »
i could not reproduce that error on a different machine
smching
« Reply #5 on: May 30, 2013, 08:30:38 am »
I encounter similar error too.
I'm getting following error when compile SoftSerialExample
I'm using DigisparkArduino-Win32-1.0.4-May19
smching
« Reply #6 on: May 30, 2013, 08:49:16 am »
After removed the following lines from SoftSerialExample, compile successfully.
// Open serial communications and wait for port to open:
  Serial.begin(57600);
   while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.println("Goodnight moon!");
RC Navy
« Reply #7 on: May 30, 2013, 12:43:02 pm »
smching,
you were trying to compile an example dedicated to regular arduino: uno, mega...
<SoftSerial> library was not designed only for Digispark, it was also designed for regular arduinos.
"Serial" refers to an hardware UART which do not exist on the Digispark.
As already stressed somewhere in the forum, it's very difficult to manage common libraries for regular arduinos AND for the Digispark.
Regards,
