Seriously guys - a digispark without the USB circuitry and with the LEDs disconnected is just an attiny85 and a 5v linear regulator. Get some superglue and stick a 5v regulator and tiny85 chips together and solder on some wires and hey presto, you just got yourself a crappy ~$4 digispark clone! If you hook up an avr programmer (like a digispark running the littlewire software) you can use current versions of the digispark software to upload a USB bootloader to your digispark clone, and after that you can make cables with resistors and zenners built right in, which is actually
exactly what I used when I was making the Micronucleus bootloader for digispark before I actually had any digisparks! Put the resistors and stuff in with the USB plug them cover it in colourful sculpey and bake for ten minutes for a pretty USB plug!
Aaaanyway, seriously, you guys should check out regular attiny85 chips. You can power them off anything between about 2.8 and 5.5 volts directly - if you need higher voltages get a linear regulator. They are rediculously handy. If you aren't doing USB stuff the digispark is functionally just an attiny85 and a linear regulator. Don't fuss so much over this stuff. It's all already built in to these $3 chips!
If what you want is a digispark without all the stuff, atmel already sells them in a dip package.
