I purchased 5 digisparks as part of your kickstarter, and finally got time to do something with one of them today.
My problem is, I can't get Mac OS X to recognize any of them (I tried two separate computers, running different versions of Mac OS X, and tried with a USB extension cable).
3 of them, when connected, light the power LED, delay 5 seconds, and start blinking the activity LED
1, when connected, lights the power LED, but never blinks the activity LED (on close inspection, two of the surface mount resistors are out of position, and undoubtedly causing problems), photos at
https://dl.dropbox.com/u/77735649/IMG_0220.JPG and
https://dl.dropbox.com/u/77735649/IMG_0221.JPGThe fifth was loaned out, and I've no idea if it works.
None appear in the USB section of the System Information application.
None appear in IORegistryExplorer.
Attempting to upload a test sketch in Arduino nets the following:
Binary sketch size: 758 bytes (of a 6,012 byte maximum)
Running Digispark Uploader...
> Device search timed out
What should I try next?
