Author Topic: Read ADC value from desktop application  (Read 5739 times)
steffen
« on: September 11, 2012, 06:19:29 am »
Hello community,
I have an Arduino based setup that reads an ADC value every 50 msecs and pushes it to a computer. This is done via a java application that listens on a virtual serial interface provided by a FTDI driver.
My question: How can I get this to work with the Digistump?
In other words: How can I use the Digistumps' ADC in a desktop application?
Regards
Steffen
« Last Edit: September 11, 2012, 06:19:29 am by steffen »
sparr
« Reply #1 on: September 12, 2012, 12:54:07 pm »
you should be able to just connect the FTDI cable to the serial pins on the digispark and use the Arduino Serial library to send output
steffen
« Reply #2 on: September 12, 2012, 02:02:28 pm »
Thank you for your reply. I think you got me wrong: I want to use the USB port of the digispark to communicate with the computer and don\'t want to use another chip. Is there a way to get that working?
ellipsisjcs
« Reply #3 on: September 19, 2012, 10:45:10 am »
Stemming from Steffen\'s question, is there a way to use the digispark as an USB/serial interface with a computer?  In other words, can you repurpose the digispark as an FTDI programmer similar to what\'s shown here: http://www.instructables.com/id/Arduino-Examples-2-Use-an-Arduino-as-a-FTDI-Progr/step3/Program-The-Arduino/
Thanks in advance from a beginner arduino hobbyist.  Looking forward to tinkering with microcontrollers!
« Reply #4 on: September 20, 2012, 12:12:24 pm »
@steffen and @ellipsisjcs - it\'s possible to use it as a serial device, but we won\'t be formally supporting that out of the gate - the preferred way to do this will be to talk to it as a USB hid device - we will have full docs, libraries, and demos on how to do this by the time we ship
« Reply #5 on: November 03, 2012, 06:24:59 pm »
The digispark can run the http://littlewire.cc/ firmware out of the box - so if you use that you get two analog inputs and libraries for querying them from all sorts of different programming languages on Mac, Windows, and Linux (including my own ruby library!)
« Reply #6 on: November 03, 2012, 06:28:33 pm »
@ellipsisjcs: Yes, you totally can do that too! The http://littlewire.cc/ project includes a cdc232 firmware which allows the digispark (or littlewire) to work as a USB serial converter. It\'s technically not compliant with the USB specification, but it mostly works anyway. cdc232 pretends to be a USB dialup modem sort of gadget, just as the Arduino Uno does, so unlike the FTDI cables, it requires no drivers - they are built in to all modern computers.
