Author Topic: wireless / rfm12b (yet more n00b questions)  (Read 3696 times)
dagb
« on: September 02, 2012, 01:23:07 pm »
It appears you have left out the 3.3V pin?
How do you intend to drive the rfm12b shield, which requires 2.2V-3.8V?
PWM? Sorry if the answer to this is obvious, I have very little exposure to Arduino so far.
Do you expect our Asian friends to start shipping knockoffs of these by Christmas? :-)
« Last Edit: September 02, 2012, 01:23:07 pm by dagb »
fraguada
« Reply #1 on: September 04, 2012, 02:01:43 pm »
From the kickstarter:
RFM12B wireless Shield PCB - added 8/27
Note: This shield is experimental, it is known to work with the Digispark and ATTINY85s but may require some tinkering. For that reason we are only offering it as a PCB. It requires the RFM12B Module (https://www.sparkfun.com/products/9582), 3x 10k resistors, 3x 4.7k x resistors, a 10µ capacitor, and a 0.1µ capacitor. It will use 5 pins (leaving 1).
Aren\'t all these resistors and caps enough to regulate the 5v down?
dagb
« Reply #2 on: September 05, 2012, 10:39:33 am »
That would make sense, yes.
yukivx
« Reply #3 on: October 05, 2012, 09:18:25 am »
I chose the RFM12B wireless Shield PCB. However, I may not be able to handle it...
When I want to build wireless network in Digispark, do I need two RFM12B wireless Shield PCB?
« Last Edit: October 05, 2012, 09:29:12 am by yukivx »
« Reply #4 on: October 05, 2012, 10:58:06 am »
You\'ll need two modules to communicate between two Digisparks, or a module hooked to another device.
Re 3.3V - The kickstarter info is outdated at this point, we\'ve updated the board to include a 3.3V regulator as well, since the Digispark board does not have 3.3v on it.
