Author Topic: Newb - Digi RGB help - Only Green outputs  (Read 4275 times)
UncleTony
« on: February 24, 2013, 08:07:01 pm »
Hey everyone, so I fried my last USB but decided to get it a new try. Got the RGB and even the LCD to light up - which is awesome.
So I decided to start with the RGB one because it's simpler to get working. I plug it in and the green only strobes, then I run the code:
  // initialize the LED pins as outputs
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  digitalWrite(0, HIGH);      // turn the Red LED On
  delay(100);              // wait for a second
  digitalWrite(1, HIGH);      // turn the Green LED On
  delay(10);              // wait for a second
  digitalWrite(2, HIGH);      // turn the Blue LED On
  digitalWrite(0, LOW);       // turn the Red LED off
  digitalWrite(1, LOW);     // turn the Green LED off
  digitalWrite(2, LOW);     // turn the Blue LED off
  delay(1000);              // wait for a second
And it only flashes green. I changed the pins to write 0 or 2 and it doesnt flash at all.
Bummer. Anyone know why it only shows green?
Thanks!
Mark
Re: Newb - Digi RGB help - Only Green outputs
« Reply #1 on: February 24, 2013, 08:35:26 pm »
You might want to look at your times.
You can turn all three ON at once, then have a single delay and turn them all OFF
  delay(100);              // wait for a second              ******this is 100mS
  delay(10);              // wait for a second               ******this is 10mS
  delay(1000);              // wait for a second             ******this is 1sec
To turn each on in turn try  ..(*** untested ***)
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
  pinMode(2, OUTPUT);
  digitalWrite(0, HIGH);      // turn the Red LED ON
  delay(2000);                // wait 2 seconds
  digitalWrite(0, LOW);      // turn the Red LED OFF
  delay(1000);
  digitalWrite(1, HIGH);      // turn the Green LED ON
  digitalWrite(1, LOW);      // turn the Green LED OFF
  delay(1000);
  digitalWrite(2, HIGH);      // turn the Blue LED ON
  digitalWrite(2, LOW);      // turn the Blue LED OFF
  delay(1000);
mark
UncleTony
« Reply #2 on: February 26, 2013, 08:06:30 am »
Thank you for adding this, again, only the green LED is lighting up. I'm wondering if I did something wrong when wiring... hmm
UncleTony
« Reply #3 on: February 26, 2013, 08:27:39 am »
wow so weird, i went back thru with my soldering iron and i must suck at soldering. cause I just cleaned up some lines and now blue works... !... kinda weird since I'm still missing the third color, but Im wondering which pin isn't perfect now that only green and blue work. hah this is weird
UncleTony
« Reply #4 on: February 26, 2013, 08:37:39 am »
SOLVED: re soldered my P0-P2 and to my surprise it works!
Thanks for helping me out with this, I can finally start messing with code.
Thanks everybody
#closed
