Author Topic: No DigiUSB Device Found - mac 10.8.1 (mid 2010)  (Read 3560 times)
wranglerdriver
« on: February 23, 2013, 10:53:53 am »
I am able to load programs onto the digispark and run them (i have tried the test led, and DigiSparkRGB).
But when i load DigiBlink, and then try to run DigiRGB or DigiBlink-Cheerlights they do not work.  I also tried loading Echo and using send.py and receive.py.  Each reports No DigiUSB Device Found.
I have tried this hooked directly to the mac, with and extension cable, and with a hub.
Am i doing something wrong?
Thanks for your help.
Re: No DigiUSB Device Found - mac 10.8.1 (mid 2010)
« Reply #1 on: February 23, 2013, 11:25:44 am »
Have you installed pyusb? Sometimes this has to do with permissions as well - can you try running the python script with sudo?
wranglerdriver
« Reply #2 on: February 23, 2013, 12:25:31 pm »
Thanks for your reply.
I have installed pyusb and tried running the programs with sudo.  still no luck.
thanks, again
« Reply #3 on: February 23, 2013, 04:12:58 pm »
This is likely a Libusb issue - which on Mac gets a bit beyond me - maybe try installing libusb-compat via homebrew
also check this thread: http://digistump.com/board/index.php/topic,199.html
and there is also a digiusb ruby gem which might be easier to get working - a few threads about that on here with some helpful hints if you need them
