Author Topic: Can I use PulseSensor if I get only Digispark?  (Read 3871 times)
yukivx
« on: August 29, 2012, 05:57:44 am »
Hello. I'm very new to Arduino. However, I want to use the PulseSensor.
I heard that PulseSensor is usable if DigiSpark has analog input. Can I use PulseSensor if I get only Digispark? Is there anything else I need?
And... If I want to use power supply from the battery, do I need Boost Shield Kits and 2xAA Battery Holder?
PulseSensor
http://pulsesensor.com
http://www.makershed.com/Pulse_Sensor_for_Arduino_5_Volt_p/mkre1.htm
Thank you. :)
« Last Edit: August 29, 2012, 06:00:42 am by yukivx »
MichaelMeissner
« Reply #1 on: August 29, 2012, 06:56:49 am »
The pulse sensor appears to a standard sensor 3 wire connector.  You would either need some 22 gauge jumper wire to connect the 3 pins of the 3 wire connector to the digispark, or you would get breakout board A which I believe the sensor would plug directly into.  You would be able to use pins p2 - p5 to read from the sensor.
MichaelMeissner
« Reply #2 on: August 29, 2012, 06:59:42 am »
There are many different battery scenarios.  It might be useful if the team could list them.
yukivx
« Reply #3 on: August 29, 2012, 03:35:23 pm »
Hi MichaelMeissner,
Thank you for your advice! :) I think that I will pledge Breakout Shield A Kits in consideration of various methods. I look forward to Digispark.
It is interesting for me..
http://makeprojects.com/Project/Beating-Heart-Headband/1622/
Thanks again,
Yukihisa
« Last Edit: August 29, 2012, 06:35:07 pm by yukivx »
yukivx
« Reply #4 on: September 26, 2012, 09:58:56 pm »
It was sold out. However Pulse Sensor is now in stock.
http://pulsesensor.myshopify.com/
