Author Topic: ATtiny85 Pinouts  (Read 16307 times)
Mark
ATtiny85 Pinouts
« on: February 18, 2013, 12:21:59 pm »
I thought I had put this link up earlier.
http://www.pighixxx.com/pgdev/Temp/attiny.pdf
This work is being done by Alberto and he is covering most versions of Arduino.
http://arduino.cc/forum/index.php?PHPSESSID=16e64b1ad04ca4b8263c52d65465e238&topic=146315.0
maybe Erik could 'persuade' him by bribery for a Digispark version...
mark
semicolo
Re: ATtiny85 Pinouts
« Reply #1 on: February 19, 2013, 06:49:39 am »
Nice work that guy did! Well it wouldn't be too hard to make a digispark version from the attiny85 pinout, it would be better to have a vector file to work from though (if that's what he used).
Mark
« Reply #2 on: February 19, 2013, 08:44:37 am »
I think Alberto did do some, and made some that were editable.
He may have taken them down.
You can always ask him......
Mark
semicolo
« Reply #3 on: February 19, 2013, 09:04:57 am »
Just did.
Mark
« Reply #4 on: March 01, 2013, 04:45:59 am »
Semicolo
Did you get an answer?
I managed to load a normal pdf version in inscape and edit it.
Some of the text needed playing with as it wasn't treated quite right for editing.
mark
semicolo
« Reply #5 on: March 01, 2013, 05:22:01 am »
Nope, no reply, I've generated a picture of the digispark itself from the eagle layout, it just needs the pins added, do you want it to add to your work?
Mark
« Reply #6 on: March 01, 2013, 05:50:09 am »
Only if you can find another 20 hours or so in a day.
After next week I might have more time...
I modified an UNO to match a Funduino board (Terry King sells them as Yourduino)
So it wasn't a whole other drawing.
Send me a PM and I'll send you my email...it can't hurt to look.
Mark
semicolo
« Reply #7 on: March 01, 2013, 05:51:31 am »
Then send me your svg and I'll try making it at lunch hour.
Mark
« Reply #8 on: March 01, 2013, 06:06:10 am »
I've sent a PM
I can't post it here, its too big.
mark
semicolo
« Reply #9 on: March 02, 2013, 10:33:36 am »
Here's with what Mark and I ended up.
If you have suggestions, fixes (grammar/spelling welcome too), thoughts, let me now.
I'm not sure about PWM on P3 but since it's /OC1B it should be available, maybe just not enabled in the arduino IDE.
Maybe add max pin/package current?
Mark
« Reply #10 on: March 02, 2013, 01:43:54 pm »
Pierre has done a marvelous job of this.
Here is a .pdf in case someone can't open .svg files
Mark
semicolo
« Reply #11 on: March 03, 2013, 08:21:20 am »
Latest Version, electrical characteristics added, changed the warning about P5 a bit
semicolo
« Reply #12 on: July 15, 2013, 12:31:01 pm »
Added warning about ADC conversion on P3.
The zip file contains the Inkscape SVG version.
« Last Edit: July 15, 2013, 12:32:44 pm by semicolo »
