Author Topic: 9V Battery Clip Shield  (Read 7019 times)
cliffbhill
« on: August 25, 2012, 08:52:12 am »
Would be nice to have a shield that clips onto a 9V battery.
« Last Edit: August 25, 2012, 08:52:12 am by cliffbhill »
sparr
« Reply #1 on: August 25, 2012, 02:23:31 pm »
That\'s literally just any other shield with a 9V battery connector soldered to the GND and VIN pins.
« Last Edit: August 25, 2012, 02:23:50 pm by sparr »
cliffbhill
« Reply #2 on: August 25, 2012, 06:04:10 pm »
Not talking about just an electrical connection.
To go battery powered, you need some battery holder wired to the board (w/ boost ) which will then need to be secured.
If you had a shield with the 9V + & - connectors mounted to the board, you\'d take care of the electrical and physical mounting in one.
sparr
« Reply #3 on: August 25, 2012, 10:32:57 pm »
That seems unnecessarily restrictive. If you solder a 9V connector with wires (http://www.led-tech.de/images/products/resized/LT-362-1264685968.jpg) onto the board then you can position the battery wherever you want in relation to the digispark and other shields. If you had a shield with 9V terminals directly attached to it, you\'d have to have the battery sticking up from the shield.
MichaelMeissner
« Reply #4 on: August 27, 2012, 05:55:58 am »
I\'ve been reading in the other Arduino groups that the 9v battery meant for fire  alarms is not that suitable for Arduinos long term, since you are wasting about 1/2 of the power of the battery, and it doesn\'t have much capacity.  But it is very convenient, in that you only have one battery to deal with and it is a reasonable size.
cliffbhill
« Reply #5 on: August 27, 2012, 04:51:46 pm »
Yes, not the most efficient power wise, but enough VIN for motors, etc. and super convenient.
Made a quick sketch of the idea in sketchup.
http://sketchup.google.com/3dwarehouse/details?mid=5f392457e9aed9e0d1cad3f0e16ef824&prevstart=0
