Author Topic: RGB with BT  (Read 3378 times)
Js3
RGB with BT
« on: February 13, 2013, 02:58:46 pm »
Im unable to find which pins are for RX, TX. Would I be able to use an RGB led and attach a Bluetooth module with the RX, TX pins. Are there enough pins to this?
Re: RGB with BT
« Reply #1 on: February 13, 2013, 03:32:38 pm »
Probably just use the software serial library - it works on any pins. 3 + 2 = 5, leaves you one spare pin.
