Author Topic: DigiSpark and DC relay input issue  (Read 3441 times)
XtremeIN
« on: February 10, 2013, 05:37:42 pm »
Hello all,
I am trying to use a DigiSpark along with three DC Relay boards from DigiStump to run a traffic light.  I wrote the sketch without an input trigger to start the cycle.  It works perfect. I cannot get the input trigger to work, no matter what I do the light test runs and then the light cycle starts without the input trigger.
int motionSensor = 2;
int redLight = 3;
int yellowLight = 4;
int greenLight = 5;
  pinMode(motionSensor, INPUT);
  pinMode(redLight, OUTPUT);
  pinMode(yellowLight, OUTPUT);
  pinMode(greenLight, OUTPUT);
  for (int Lighttest = 0; Lighttest < 4; Lighttest ++)
    digitalWrite(redLight, HIGH);
    digitalWrite(yellowLight, HIGH);
    digitalWrite(greenLight, HIGH);
    delay(500);
    digitalWrite(redLight, LOW);
    digitalWrite(yellowLight, LOW);
    digitalWrite(greenLight, LOW);
    delay(500);
  if (motionSensor == x?x )
    delay(3000);
    delay(1500);
    delay(3000);
  else
I have tried with the motionSensor == to HIGH and LOW. Is the sketch correct and my wiring wrong?
thank you,
Micheal
Mark
Re: DigiSpark and DC relay input issue
« Reply #1 on: February 10, 2013, 06:53:33 pm »
XtremeIN
try this :-
  if (digitalRead(motionSensor) == x?x )
You need to read the input.
Not logical I agree .... but thats how it is.
You can also do a xyz = digitalRead(motionSensor), then do if (xyz == HIGH).
Cheers
Mark
XtremeIN
« Reply #2 on: February 10, 2013, 08:31:05 pm »
thanks Mark,
I had it written that way to start with. Not sure what happened, but I changed the code back to the way I started with/you suggested and went through all my wiring and now it works......
Micheal
Mark
« Reply #3 on: February 10, 2013, 08:58:20 pm »
Micheal
Been there done that.
Even worse is the if without the double equals ...that's hard for a novice to spot.
Glad its working.
Mark
