Author Topic: Upgrading firmware on clone (rev 3)  (Read 3665 times)
rev
« on: October 17, 2019, 06:38:44 am »
Hello.
I received some cloned digistumps (rev 3) and i'm wondering if anyone here has any advice on updating their firmware? They seem to be a bit finicky at the moment.
I ran zadog which says they are running libusb0 (v1.2.6.0). Arduino claims device firmware is 1.6. Can i do something to improve their reliability?
Sometimes when plugged in they don't run the program.
Also, will digistumps generally be damaged by unplugging mid execution? I guess not since it loops forever once program is done but just wanted to check.
rubberduck
Re: Upgrading firmware on clone (rev 3)
« Reply #1 on: November 06, 2019, 06:04:28 am »
You can upload this via the micronucleus executeable: https://github.com/micronucleus/micronucleus/raw/master/upgrade/releases/upgrade-t85_default.hex
./micronucleus --run upgrade-t85_default.hex
Please give some seconds (maximum 30) to finish the upgrade as this is a sketch which is uploaded with the old bootloader and then will be run. It's only task is then to upgrade the bootloader and kill itselves after that.
