Author Topic: Absolute mouse position  (Read 2891 times)
achtaitaipai
« on: September 15, 2019, 11:17:18 am »
Hey everyone,
I'm searching a way to move cursor by sending screen position.
Can someone help me?
thank you in advance
granzeier
Re: Absolute mouse position
« Reply #1 on: September 15, 2019, 05:53:17 pm »
I'm not understanding what you want. Are you looking for some program on the PC to read the X,Y position of the cursor, send it to the Digispark, and then have the Digispark send mouse movement commands to move the mouse to a new specific location?
achtaitaipai
« Reply #2 on: September 16, 2019, 10:57:28 am »
Sorry my english is bad...
I'm looking for a way to send coordinate to the cursor and not movement.
I've found this library for arduino leonardo https://github.com/jonathanedgecombe/absmouse
but this is not working for digispark.
granzeier
« Reply #3 on: September 17, 2019, 03:44:24 am »
I'm thinking that this could be done by using the regular mouse movement statements, just precede them with a command to move the mouse to a known position (like 0,0).
// Move mouse to position (500,250) - 500 pixels from left side, 250 pixels from top
DigiMouse.moveY(-2000,-1000); // Move cursor left 2000 pixels (some number greater than the width of the screen) and up 1000 pixels (again, some number greater than the height of the screen - This will place the cursor at a known position (0,0) since you cannot move the cursor beyond the screen.
DigiMouse.moveY(500,250); // Move position to desired place on screen
Now, I have not tested this, but looking things over, it seems that it should work.
achtaitaipai
« Reply #4 on: September 17, 2019, 10:47:24 am »
Thank you ! this is a good idea.
But this is not working.
After some searchs, it's look like the maximum value is 127.
"DigiMouse.move(-2000, -1000, 0);" is not working.
achtaitaipai
« Reply #5 on: September 17, 2019, 11:57:43 am »
I've found something who works (little bit)
thanks to this : https://forum.arduino.cc/index.php?topic=94140.0
i made this :
 * Based on Obdev's AVRUSB code and under the same license.
 * TODO: Make a proper file header. :-)
 * Modified for Digispark by Digistump
 * And now modified by Sean Murphy (duckythescientist) from a keyboard device to a mouse device
 * Most of the credit for the joystick code should go to Rapha? Ass?at
 * And now mouse credit is due to Yiyin Ma and Abby Lin of Cornell
#ifndef __DigiMouse_h__
#define __DigiMouse_h__
#define REPORT_SIZE 4
#include <Arduino.h>
#include <avr/pgmspace.h>
#include <avr/interrupt.h>
#include <avr/delay.h>
#include <string.h>
#include <avr/io.h>
#include <avr/sleep.h>
#include <avr/wdt.h>
#include "usbdrv.h"
//#include "devdesc.h"
#include "oddebug.h"
#include "usbconfig.h"
static const uchar *rt_usbHidReportDescriptor = NULL;
static uchar rt_usbHidReportDescriptorSize = 0;
static const uchar *rt_usbDeviceDescriptor = NULL;
static uchar rt_usbDeviceDescriptorSize = 0;
#define MOUSEBTN_LEFT_MASK 0x01
#define MOUSEBTN_RIGHT_MASK 0x02
#define MOUSEBTN_MIDDLE_MASK 0x04
// TODO: Work around Arduino 12 issues better.
//#include <WConstants.h>
//#undef int()
typedef uint8_t byte;
/* What was most recently read from the controller */
static unsigned char last_built_report[REPORT_SIZE];
/* What was most recently sent to the host */
static unsigned char last_sent_report[REPORT_SIZE];
uchar reportBuffer[REPORT_SIZE];
// report frequency set to default of 50hz
#define DIGIMOUSE_DEFAULT_REPORT_INTERVAL 20
static unsigned char must_report = 0;
static unsigned char idle_rate = DIGIMOUSE_DEFAULT_REPORT_INTERVAL / 4; // in units of 4ms
// new minimum report frequency system:
static unsigned long last_report_time = 0;
char usb_hasCommed = 0;
const PROGMEM unsigned char mouse_usbHidReportDescriptor[] = { /* USB report descriptor */
0x05, 0x01, // USAGE_PAGE (Generic Desktop)
0x09, 0x02, // USAGE (Mouse)
0xa1, 0x01, // COLLECTION (Application)
0x09, 0x01, // USAGE_PAGE (Pointer)
0xa1, 0x00, // COLLECTION (Physical)
0x05, 0x09, // USAGE_PAGE (Button)
0x19, 0x01, // USAGE_MINIMUM (Button 1)
0x29, 0x03, // USAGE_MAXIMUM (Button 3)
0x15, 0x00, // LOGICAL_MINIMUM (0)
0x25, 0x01, // LOGICAL_MAXIMUM (1)
0x95, 0x03, // REPORT_COUNT (3)
0x75, 0x01, // REPORT_SIZE (1)
0x81, 0x02, // INPUT (Data,Var,Abs)
0x95, 0x01, // REPORT_COUNT (1)
0x75, 0x05, // REPORT_SIZE (5)
0x81, 0x01, // Input(Cnst)
0x05, 0x01, // USAGE_PAGE(Generic Desktop)
0x09, 0x30, // USAGE(X)
0x09, 0x31, // USAGE(Y)
0x15, 0x01, // LOGICAL_MINIMUM (-127)
0x25, 0x78, // LOGICAL_MAXIMUM (127)
0x75, 0x08, // REPORT_SIZE (8)
0x95, 0x02, // REPORT_COUNT (2)
0x81, 0x02, // INPUT (Data,Var,Rel)
0x09, 0x38, // Usage (Wheel)
0x95, 0x01, // Report Count (1),
0x81, 0x06, // Input (Data, Variable, Relative)
0xc0, // END_COLLECTION
0xc0 // END_COLLECTION
#define USBDESCR_DEVICE 1
const unsigned char usbDescrDevice[] PROGMEM = { /* USB device descriptor */
18, /* sizeof(usbDescrDevice): length of descriptor in bytes */
USBDESCR_DEVICE, /* descriptor type */
0x01, 0x01, /* USB version supported */
USB_CFG_DEVICE_CLASS,
USB_CFG_DEVICE_SUBCLASS,
0, /* protocol */
8, /* max packet size */
USB_CFG_VENDOR_ID, /* 2 bytes */
USB_CFG_DEVICE_ID, /* 2 bytes */
USB_CFG_DEVICE_VERSION, /* 2 bytes */
#if USB_CFG_VENDOR_NAME_LEN
1, /* manufacturer string index */
#else
0, /* manufacturer string index */
#endif
#if USB_CFG_DEVICE_NAME_LEN
2, /* product string index */
#else
0, /* product string index */
#endif
#if USB_CFG_SERIAL_NUMBER_LENGTH
3, /* serial number string index */
#else
0, /* serial number string index */
#endif
1, /* number of configurations */
void buildReport(unsigned char *reportBuf) {
if (reportBuf != NULL) {
memcpy(reportBuf, last_built_report, REPORT_SIZE);
memcpy(last_sent_report, last_built_report, REPORT_SIZE);
void clearMove() {
// because we send deltas in movement, so when we send them, we clear them
last_built_report[1] = 0;
last_built_report[2] = 0;
last_built_report[3] = 0;
last_sent_report[1] = 0;
last_sent_report[2] = 0;
last_sent_report[3] = 0;
class DigiMouseDevice {
 public:
DigiMouseDevice () {
rt_usbHidReportDescriptor = mouse_usbHidReportDescriptor;
rt_usbHidReportDescriptorSize = sizeof(mouse_usbHidReportDescriptor);
rt_usbDeviceDescriptor = usbDescrDevice;
rt_usbDeviceDescriptorSize = sizeof(usbDescrDevice);
void begin() {
cli();
usbDeviceDisconnect();
_delay_ms(200);
usbDeviceConnect();
usbInit();
sei();
last_report_time = millis();
void refresh() {
update();
void poll() {
update();
void update() {
usbPoll();
// instead of above code, use millis arduino system to enforce minimum reporting frequency
unsigned long time_since_last_report = millis() - last_report_time;
if (time_since_last_report >= (idle_rate * 4 /* in units of 4ms - usb spec stuff */)) {
last_report_time += idle_rate * 4;
must_report = 1;
// if the report has changed, try force an update anyway
if (memcmp(last_built_report, last_sent_report, REPORT_SIZE)) {
must_report = 1;
// if we want to send a report, signal the host computer to ask us for it with a usb 'interrupt'
if (must_report) {
if (usbInterruptIsReady()) {
must_report = 0;
buildReport(reportBuffer); // put data into reportBuffer
clearMove(); // clear deltas
usbSetInterrupt(reportBuffer, REPORT_SIZE);
// delay while updating until we are finished
void delay(long milli) {
unsigned long last = millis();
  while (milli > 0) {
    unsigned long now = millis();
    milli -= now - last;
    last = now;
    update();
void moveX(char deltaX) {
if (deltaX == -128) deltaX = -127;
last_built_report[1] = *(reinterpret_cast<unsigned char *>(&deltaX));
void moveY(char deltaY) {
if (deltaY == -128) deltaY = -127;
last_built_report[2] = *(reinterpret_cast<unsigned char *>(&deltaY));
void scroll(char deltaS) {
if (deltaS == -128) deltaS = -127;
last_built_report[3] = *(reinterpret_cast<unsigned char *>(&deltaS));
void move(char deltaX, char deltaY, char deltaS) {
void move(char deltaX, char deltaY, char deltaS, char buttons) {
last_built_report[0] = buttons;
void rightClick(){
last_built_report[0] = MOUSEBTN_RIGHT_MASK;
void leftClick(){
void middleClick(){
void setButtons(unsigned char buttons) {
void setValues(unsigned char values[]) {
memcpy(last_built_report, values, REPORT_SIZE);
//private: TODO: Make friend?
// what does this even mean? -- Bluebie
// create the global singleton DigiMouse
DigiMouseDevice DigiMouse = DigiMouseDevice();
#ifdef __cplusplus
extern "C"{
#endif
// USB_PUBLIC uchar usbFunctionSetup
uchar usbFunctionSetup(uchar data[8]) {
usbRequest_t *rq = (usbRequest_t *)data;
usbMsgPtr = reportBuffer;
if ((rq->bmRequestType & USBRQ_TYPE_MASK) == USBRQ_TYPE_CLASS) { /* class request type */
if (rq->bRequest == USBRQ_HID_GET_REPORT) { /* wValue: ReportType (highbyte), ReportID (lowbyte) */
/* we only have one report type, so don't look at wValue */
//curGamepad->buildReport(reportBuffer);
//return curGamepad->report_size;
return REPORT_SIZE;
} else if (rq->bRequest == USBRQ_HID_GET_IDLE) {
usbMsgPtr = &idle_rate;
return 1;
} else if (rq->bRequest == USBRQ_HID_SET_IDLE) {
idle_rate = rq->wValue.bytes[1];
} else {
/* no vendor specific requests implemented */
return 0;
uchar usbFunctionDescriptor(struct usbRequest *rq) {
if ((rq->bmRequestType & USBRQ_TYPE_MASK) != USBRQ_TYPE_STANDARD) {
return 0;
if (rq->bRequest == USBRQ_GET_DESCRIPTOR) {
// USB spec 9.4.3, high byte is descriptor type
switch (rq->wValue.bytes[1]) {
case USBDESCR_DEVICE:
usbMsgPtr = rt_usbDeviceDescriptor;
return rt_usbDeviceDescriptorSize;
break;
case USBDESCR_HID_REPORT:
usbMsgPtr = rt_usbHidReportDescriptor;
return rt_usbHidReportDescriptorSize;
break;
return 0;
#ifdef __cplusplus
} // extern "C"
#endif
#endif // __DigiMouse_h__
you can try it by changing the file DigiMouse.h
and it works except for the bottom, right corner
achtaitaipai
« Reply #6 on: September 18, 2019, 08:31:27 am »
I found a solution.
in case it could help someone.
The modified version of DigiMouse.h
#include <string.h>
#include <avr/io.h>
#include "usbdrv.h"
//#undef int()
//#define ABSOLUTE_MOUSE_MODE
#ifdef ABSOLUTE_MOUSE_MODE
0x15, 0x01, // LOGICAL_MINIMUM (0)
0x25, 0x7f, // LOGICAL_MAXIMUM (120)
#else
0x15, 0x81, // LOGICAL_MINIMUM (-127)
0x25, 0x7f, // LOGICAL_MAXIMUM (127)
0x81, 0x06, // INPUT (Data,Var,Rel)
#endif
0, /* protocol */
#else
#endif
#else
#endif
#else
#endif
void clearMove() {
 public:
void begin() {
cli();
_delay_ms(200);
usbDeviceConnect();
usbInit();
sei();
void refresh() {
update();
void poll() {
update();
void update() {
usbPoll();
must_report = 1;
must_report = 1;
if (must_report) {
must_report = 0;
  while (milli > 0) {
    last = now;
    update();
void rightClick(){
void leftClick(){
void middleClick(){
#ifdef __cplusplus
extern "C"{
#endif
return REPORT_SIZE;
return 1;
} else {
return 0;
return 0;
break;
break;
return 0;
#ifdef __cplusplus
} // extern "C"
#endif
and the example arduino file :
float angle = 0;
float bx = 5, by = 43;
float xspeed = 0.005;
float yspeed = 0.003;
int r = 60;
#include <DigiMouse.h>
  DigiMouse.begin();
  bx += xspeed;
  by += yspeed;
  if (bx >= 127|| bx <= 0)xspeed *= -1;
  if (by >= 127|| by < 0)yspeed *= -1;
  DigiMouse.move(bx, by, 0);
  DigiMouse.update();
thankyou granzeyer for the help :)
« Last Edit: September 18, 2019, 10:36:16 am by achtaitaipai »
granzeier
« Reply #7 on: September 19, 2019, 03:24:08 am »
I'm glad that you were able to figure it out.
