Author Topic: Update successful according to particle, but new code not running  (Read 199 times)
kaokub99
Hi!
I haven't used my oak for some time and now when I brought it out again I have run into a strange issue. It connects to wifi and particle cloud and seems to run some software I programmed it with last time. When i try to load new software (tested different example code) to it, Particle (also test with Arduino IDE) reports successful update and the oak is indicating that it is being updated by flashing led, BUT the software does not seems to be written to the oak at all since pins, onboard led, particle functions and variables are not functioning/shown. It almost seems as the oak has RO memory...
I was thinking that perhaps it could have something to do with the slots and that it reverts back to previous software for some reason. Do anyone have any advice?
> slot <
granzeier
Re: Update successful according to particle, but new code not running
« Reply #1 on: July 11, 2019, 03:00:22 am »
You would probably get better results by asking on the Oak board (http://digistump.com/board/index.php/board,20.0.html.) This board is pretty much just for support for the Digispark.
I (and most likely, many others on this board) do not have any Oaks.
KamHiva
Update successful according to particle but new code not running
« Reply #2 on: August 07, 2019, 05:31:01 am »
i try this one it will not upadate direct  but try to relog it will be updated, i thinks it will not update in the same time by  somehow or its not showen that ingame
sleepy666
« Reply #3 on: September 11, 2019, 04:58:16 am »
vegus แหล่งรวบรวมการเดิมพันออนไลน์ แทงบอลออนไลน์ บาคาร่าออนไลน์ ที่รอให้บริการโดยทีมงานมืออาชีพพร้อมให้บริการตลอด 24 ชั่วโมง
pawanverma
« Reply #4 on: September 13, 2019, 05:15:14 am »
Good information...
