Author Topic: Weirdness with SoftSerial  (Read 1958 times)
bar0n
« on: September 14, 2018, 09:24:31 am »
Been fighting with a HM-10 module for some time and as i test i tried SoftSerial_INT0 (https://github.com/J-Rios/Digispark_SoftSerial-INT0) with DigiKeyboard to see the data being passed.
when I print through the keyboard and the serial (show in the code below). it works fine (see image sc01)
#include "DigiKeyboard.h"
#include <SoftSerial_INT0.h>
SoftSerial mSerial(2, 1); // Rx, Tx
  mSerial.begin(9600);
  static char cmd;
  if(mSerial.available())
    cmd = mSerial.read();
    DigiKeyboard.print(cmd);
    mSerial.write(cmd);
    if (cmd == '\n') {
      DigiKeyboard.println("OK");
      mSerial.write("OK\n");
  DigiKeyboard.update();
however if I just write through the serial by commenting out the keyboard.print lines, the characters get skewed (see image sc02)
//    DigiKeyboard.print(cmd);
    mSerial.write(cmd);
    if (cmd == '\n') {
//      DigiKeyboard.println("OK");
Can anyone explain to me why this happens and how I can get SoftSerial to work with DigiKeyboard?
Also, note I was getting the same issue when using the original SoftSerial and TinyPinChange.
Other Details:
android App: Serial Bluetooth Terminal by Kai Morich
Wiring: see image wiring.jpg
bar0n
Re: Weirdness with SoftSerial
« Reply #1 on: September 14, 2018, 09:31:56 am »
Just realized the wiring diagram was wrong. here's the correct one.
